| Home > Help Needed / General Tech Chat > please help | |||||||
![]() 52 Posts Member #: 593 Advanced Member woking, surrey |
5th Aug, 2005 at 10:49:10am
please help at my wits end and have loooked of the site but nothing like my problem era turbo - not even the mrs gets to drive it |
5th Aug, 2005 at 10:55:27am
Have you checked the oil level in the carb dashpot? Unscrew the black plastic cap, should be some oil in there, fill it to the ridge. Use engine oil, something like 20/50. The haynes manual will tell you how to do it if you are not sure.
5th Aug, 2005 at 11:28:39am
Obviously a fuel issue.
Edited by giallofly on 5th Aug, 2005. On 21st Jan, 2011 fastcarl said:
5th Aug, 2005 at 11:42:30am
chokes a good one, sometimes the fibreglass heatsheild can prevent the choke from going all the way home. Maybe the carb is just in need of a good rebuild? |
5th Aug, 2005 at 12:04:42pm
dash pot is ok level timing is out by 3 degrees havent cheacked the heat shield seems strange though cos its been running fine era turbo - not even the mrs gets to drive it |
5th Aug, 2005 at 12:17:40pm
choke returns fine and no i have never had the plemum chamber off any thought please do suggest era turbo - not even the mrs gets to drive it |
5th Aug, 2005 at 06:53:22pm
Is it actually choking from over fuelling, or is it misfiring from leaning out ? checked fuel pressure ?
5th Aug, 2005 at 07:24:39pm
This sounds oh -so- typical of the balance pipe being split, or the carb vent solenoid not working...
5th Aug, 2005 at 07:29:52pm
yup exactly the same as mine until i found out how to plumb it in properly, so i'd guess at a split hose aswell. On 20th Oct, 2015 Tom Fenton said:
5th Aug, 2005 at 11:51:47pm
have you tried the coil mine used to do that till i changed it, try the other options first though none seem too hard or expensive. |
6th Aug, 2005 at 06:49:09am
could be coil, or float valve leaking when on boost, as td says could balance pipe split. always looking for them bigger bunches of bannanas |
7th Aug, 2005 at 07:20:52pm
coil is fine but i dont no where the balance pipe is sorry new to the turbo game era turbo - not even the mrs gets to drive it |
7th Aug, 2005 at 08:25:48pm
found that the ballence pipe was split replaced but still miss firing but not at bad now era turbo - not even the mrs gets to drive it |
8th Aug, 2005 at 11:42:28pm
http://www.manchesterminis.co.uk/technical/turbo-carb.htm
9th Aug, 2005 at 06:34:47pm
cheers turbo dave well i got so pissed off at gc minis(where i brought it from) i told to fix it or ill be having my money back just dropped it off and there looking at it era turbo - not even the mrs gets to drive it |
9th Aug, 2005 at 09:53:11pm
Trouble is, it's almost guaranteed they don't know anything about turbo motors... On 17th Nov, 2014 Tom Fenton said:
10th Aug, 2005 at 06:35:35pm
had a chat with the bloke he claims nothing is wrong have sort legal advise told to get a engineers report then sue him for the damage to hav it fixed, by the way the balence pipe was split helpped a little and after the site you posted, it could be the run on valve as sometimes it does run on or am a just guessing?
