| Home > Help Needed / General Tech Chat > All the small things | |||||||
13 Posts Member #: 10856 Member Newcastle upon Tyne |
9th Jun, 2014 at 07:37:51pm
What are the little tweaks you can do the metro turbo engine that make a difference?
Tony |
9th Jun, 2014 at 08:11:30pm
You could probably write a book on that. Dont go knife edging your inlet ports if thats what you mean tho. Thats not how they work. |
9th Jun, 2014 at 08:45:57pm
I gave turbo phil my exhaust manifold and elbow, there's a lot of gain to be made opening up the elbow i believe. If you have vizards yellow bible you can probably pick up on quite a lot in there you can apply to the engine to increase its efficiency. On 26th Jan, 2012 Tom Fenton said:
9th Jun, 2014 at 08:46:48pm
No I meant the exhaust outlet on the cast manifold Tony |
9th Jun, 2014 at 08:48:09pm
That's was why I was thinking the little tweaks can make a big difference Tony |
9th Jun, 2014 at 08:50:54pm
Ahh yeh i know what you mean now. You can always turn the boost up :) |
9th Jun, 2014 at 09:15:46pm
Was thinking if I made the little tweets to up efficiency, I could keep the boost down and not risk the engine?
Tony |
9th Jun, 2014 at 09:17:26pm
Makes perfect sense, more ponies per psi. In other words you can up the power from having exactly the same boost settings. On 26th Jan, 2012 Tom Fenton said:
