| Home > General Chat > megajolt. | |||||||
13 Posts Member #: 10774 Member seaford australia |
10th Jun, 2014 at 01:43:33am
Hey Peoples,
10th Jun, 2014 at 04:54:42am
At 350,000 kilometres I suspect it is more likely to be something like a valve problem than anything to do with the megajolt.
10th Jun, 2014 at 11:11:45am
Hey tadge, the car has been service religiously every 3k. Comp is still an even 125psi in evey pot. There is no misfire or off beat sound with the original ignition system. We have mapped the same ignition curve for the megajolt. As we have done no other changes it wold suggest it has something to do with the megajolt system. We are not unhappy with the system it works great and the timing is much more accurate than the original setup. No other modern engines run a 5 port head. Cheers Ben |
10th Jun, 2014 at 11:40:33am
If it's noise you hear through the exhaust, the only relevance of it being five port is the siamesed exhaust between 2 and 3.
