| Home > Help Needed / General Tech Chat > Boost switch | |||||||
13th Jun, 2014 at 06:31:20am
Hi all
13th Jun, 2014 at 08:26:11am
Can you use the boost control output and set it to 5psi? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th Jun, 2014 at 03:44:27pm
oil pressure switch ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Jun, 2014 at 04:29:47pm
On 13th Jun, 2014 wil_h said:
Can you use the boost control output and set it to 5psi? Ooooo Wil that might be very clever... I have the plug and the solenoid I guess one pin is neg and the other one positive? I will investigate tomorrow. I guess you mean I could use the negative to switch the relay for the pump ? I did ring sc but they never mentioned that.. Edited by gr4h4m on 13th Jun, 2014. I run a supercharger and I don't care the TB is on the wrong side.
13th Jun, 2014 at 04:40:01pm
On 13th Jun, 2014 robert said:
oil pressure switch ? Robert won't rah need guild to activate rather than the vac/boost signal? I run a supercharger and I don't care the TB is on the wrong side.
13th Jun, 2014 at 05:20:31pm
There are no PWM or switched outputs you can use on the ecu ?
13th Jun, 2014 at 05:47:41pm
I had a look and there was no output that could be configured to switch on a boost level other than the PWM for the boost control.
13th Jun, 2014 at 05:53:28pm
oil pressure switch ? Robert won't rah need guild to activate rather than the vac/boost signal? um ,come again
13th Jun, 2014 at 05:57:46pm
I'm currently planning Water/Meth injection.
13th Jun, 2014 at 06:03:00pm
paul ,
13th Jun, 2014 at 06:29:42pm
Sounds a bit shit if there is no single universal switched output.
13th Jun, 2014 at 06:39:37pm
sorry Robert ive been drinking all day with customers I run a supercharger and I don't care the TB is on the wrong side.
13th Jun, 2014 at 06:43:39pm
m just using a headlight washer pump, tank and a .70 nozzle boom home brew wi
13th Jun, 2014 at 06:55:31pm
Innovation at its best:
paul , on the tvr I just used a windscreen washer pump , a boost switch ,a valve in the line to regulate flow ,and a rheostat to regulate pump speed . the nozzle was a piece of brake pipe flattened out and 3 0.5mm holes drilled in it. it was mounted before the 2nd st turbo (the small one) and worked very well , I could run 20 psi on a 9.25:1 cr on 95 octane . Very different to what I had in mind, but significantly cheaper. My ECU will run the pump at a certain boost or rpm or tps or mat, control a fast acting valve against a 3D table of duty cycle and (I think) stop the system when the tank runs dry. So no control issues. Do you get adequate atomisation from the washer pump? Aquamist use 160 psi. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
13th Jun, 2014 at 07:13:41pm
And I was just going to have a micro switch on the throttle to start the w/washer pump on full throttle ! |
13th Jun, 2014 at 07:19:43pm
On 13th Jun, 2014 Paul S said:
Innovation at its best: On 13th Jun, 2014 robert said:
paul , on the tvr I just used a windscreen washer pump , a boost switch ,a valve in the line to regulate flow ,and a rheostat to regulate pump speed . the nozzle was a piece of brake pipe flattened out and 3 0.5mm holes drilled in it. it was mounted before the 2nd st turbo (the small one) and worked very well , I could run 20 psi on a 9.25:1 cr on 95 octane . Very different to what I had in mind, but significantly cheaper. My ECU will run the pump at a certain boost or rpm or tps or mat, control a fast acting valve against a 3D table of duty cycle and (I think) stop the system when the tank runs dry. So no control issues. Do you get adequate atomisation from the washer pump? Aquamist use 160 psi. I would say that compared to the modern setups the atomisation was non existant ! but it worked . running it through the impeller would have minced it up pretty well. the rheostat was great ,you could set it at full flow ,drive it at full throttle then turn down the flow and get a big increase in acceleration then turn it up again if you went to far and it rattled . I had a light that came on on the dash when the water triggered at 7 psi , after lending the car to a friend he told me that was actually the wheelspin light lol. bear in mind this was in 1990. car ran best possible of 12.59 1/4 mile on treads and 12 psi.
Edited by robert on 13th Jun, 2014. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Jun, 2014 at 07:20:44pm
I just run a float in the tank so the system cant fire when its low.
13th Jun, 2014 at 08:04:43pm
http://s132.photobucket.com/user/Mini_Addi...V00646.mp4.html
13th Jun, 2014 at 08:24:53pm
13th Jun, 2014 at 09:48:20pm
Hahaha that was a few years ago before we ripped the kitchen out I run a supercharger and I don't care the TB is on the wrong side.
13th Jun, 2014 at 09:55:32pm
Windscreen washer pumps are very poor, low pressure really
13th Jun, 2014 at 10:19:29pm
Yep I have spoken to sc and they said they can't do it.
14th Jun, 2014 at 02:25:42pm
Wil h is a genius... Now setup using the ecu boost control I run a supercharger and I don't care the TB is on the wrong side.
