| Home > Help Needed / General Tech Chat > turbo carb | |||||||
7 Posts Member #: 10859 Junior Member |
21st Jun, 2014 at 10:34:03pm
Running rich with bdd needle which do l need
22nd Jun, 2014 at 12:37:25am
You need more boost to soak up all that extra fuel.
Edited by turbodave16v on 22nd Jun, 2014. On 17th Nov, 2014 Tom Fenton said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
22nd Jun, 2014 at 07:43:39am
what fuel pressure are you set at and are you using wideband? Done now needs redoing lol |
22nd Jun, 2014 at 10:46:26am
Its just on idle had carb rebuild still same wont pass mot but runs spot on |
22nd Jun, 2014 at 10:53:52am
It not had much mods done just had compresson lowerd by about 27cc and intercooler |
22nd Jun, 2014 at 12:19:19pm
I take it you've actually tried adjusting the mixture screw ? You'll also find if you've lowered the compression much, that you'll need more ignition advance, this will affect mixture.
22nd Jun, 2014 at 02:19:56pm
What spring are you running? it should be easy to get this to pass, unless you have turbo'd an MPi On 17th Nov, 2014 Tom Fenton said:
22nd Jun, 2014 at 02:21:31pm
Have you got a standard camshaft or an aftermarket lumpy cam as well? On 17th Nov, 2014 Tom Fenton said:
22nd Jun, 2014 at 02:53:17pm
when i took it for mot it was to rich the back of the car was black, then while it was being tested they left it running, when they came to do emissions it blew blue smoke out so failed. i have changed turbo but i still have black smoke on idle, when i rev the engine it clears. l have had this car for 5 years it has got a 244sp cam in it Edited by phil77 on 22nd Jun, 2014. |
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
22nd Jun, 2014 at 09:48:54pm
get a fuel pressure gauge on it to see exactly whats going through it. I'm amazed the guy at the garage didn't offer to do it (or I may be blessed with a nice m.o.t tester) Masturbation is not a crime its a hobby |
