Home > General Chat > radiator
tony 69
Member #: 10548
chesterfield
Hi guys can i get a little advise please.
I've been reading how some of you are now fitting the front mounted cinquecento radiator my question is do you find in your opinion that these are better than the side fitted alloy ones.
On ebay they have the side fitted ones with a 40mm core size the ones from china anyone bought one of these and if so do you find them to be any good .
CheersTony
D4VE
Member #: 10749
lowestoft suffolk
Im prob wrong but aint they the ones where u have to pay some silly import tax unless its a 'gift' ?
Nothing gets past Dave lol
wng691s clubby
Member #: 9252
Cleethorpes
i use a chinese alloy rad from the bay and there was no extra cost good cheap rads im my opinion. I haven't had a front mounted rad on my car so I cant say which works better im sure some of the other lads have tho
Done now needs redoing lol
tony 69
Member #: 10548
chesterfield
Hi Dave i dont think there's a extra charge on those rads a friend bought one from china and had no problems but i will double check if i go down that root thanks for the imput though mate all is welcome lol.
anyone running the fiat rad that can show some light on this side of things
Cheers Tony
Billus89
Member #: 8931
I purchased one of the Chinese alloy rads and didn't have to pay any further import taxes. The quality looks alright but I have yet to test, but at the low cost they are I thought I would give one a go.
tony 69
Member #: 10548
chesterfield
The one my friend bought seems pretty good from what i can see its on a big v6 engined car and as yet hes had no problems.
I have found both 40mm and 50mm cores for little difference money wise, im quite happy togive one ago i think but if the fiat is better cooling wise it could well be a far better idea.
Cheers Tony
D4VE
Member #: 10749
lowestoft suffolk
Ah ok apologies, think i saw them listing them once with a start bid of 60 aswell as a buy it now but got put off by some postage or summin? Anyone got a link to one now? Worth a shot if they are that cheap altho i have no cooling issues even at london2brighton in the scorching heat it didnt go over half but i reckon dry decking played a part, cinquencento rad sounds cool on being able to play around with different position of things
welshdan
Member #: 1111
s wales
I have a big core alloy rad, got it from min-its. has Chinese writing on it. running more than 160 bhp at 13psi, currently up to 19 psi with no cooling issues. a long hard drive, the temps will go no more than 100 degrees. it will then idle all day without overheating, even in the hot weather. the engine bay is cool, the bonnet cool to touch.
definitely worth giving a budget far east ally rad a try.
also use 4 blade metal fan, and the built in fan on the inner wing, this setup works perfectly
cheers, dan
tony 69
Member #: 10548
chesterfield
Sounds like the alloy rads are good enough for are use so think ill be orderering one.
251336659867 is the ebay number for the 40mm one.
Cheers Tony
*Clapping**Clapping*
tony 69
Member #: 10548
chesterfield
Hey Dan do you know if your rad is a 40 or 50 mm core
Cheers Tony
welshdan
Member #: 1111
s wales
Not sure doing some pre rolling road checks tomorrow can measure then if that helps.
tony 69
Member #: 10548
chesterfield
That would be great be nice to know before I buy
Cheers Tony
welshdan
Member #: 1111
s wales
my rad is around 55mm.
