Home > Help Needed / General Tech Chat > one for the good panel beaters here.
Rammie2000
Member #: 10190
belgium
Owkey so i am building up the mk1 of my wife. When i bought it some smart guy has cut out quite some metal without bracing a thing... The right hand side neede about 1cm streching to get h door in properly. ( roof needed to be braced as wel because it started to bent down 3 mm when streching) question is... will it al stay in place once welded up?
Edited by Rammie2000 on 25th Jun, 2014.
Rammie2000
Member #: 10190
belgium
Rammie2000
Member #: 10190
belgium
Rammie2000
Member #: 10190
belgium
Rammie2000
Member #: 10190
belgium
Rammie2000
Member #: 10190
belgium
The door now has about 3 mm round
Rammie2000
Member #: 10190
belgium
nobody here? got it on the spit today to weld in inner wings and so on before i set the a pans fix ( they are already adjusted to the doors and wing.
If you brace it all while in the correct place it should stay there after welding
Rammie2000
Member #: 10190
belgium
i braced it now so everething is back in place but tought of maybe giving everething a twist extra just to be sure... or not that good idea?
I wouldnt go too far, you have a lot of welding to do so straighten everything to the correct place then weld it all
Rammie2000
Member #: 10190
belgium
Okido. Thanks for the advise
