| Home > Help Needed / General Tech Chat > Layshaft play | |||||||
![]() 520 Posts Member #: 189 Post Whore Norway |
26th Jun, 2014 at 06:50:47pm
I am rebuilding a sc gearbox, and measures the lay shaft end play to 0.42 mm. The bearings are standard and not worn. The lay shaft are new, and I can not see any problems with the box itself. As far as I understand this play is way to much, even with the thickest bearing aveiable.
www.shag.no |
27th Jun, 2014 at 07:38:07pm
I've used shim steel to space out the bearings in the past. On 11th Feb, 2015 robert said:
28th Jun, 2014 at 08:07:20am
Hmm. I could swear I had replyed to this post??
www.shag.no |
28th Jun, 2014 at 02:31:10pm
