Home > Technical Chat > boost guage
1976 clubamn
Member #: 400
Shrewsbury
after changing the vacuum pipe around to where they should be today i found that under load i only get a minus reading , anyone know why this would be?
(i have taken the guage feed from the lean off point on the manifold)
also i have T'ed the dump valve into the same point.
any help would be greatfully recieved
If it breaks... build a much faster one
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
coz you've T'ed the dump valve in...
they should be on seperate lines.
Alex
AlexF
