| Home > General Chat > Fuel Line Quick Connectors | |||||||
60 Posts Member #: 1066 Advanced Member germany |
29th Jun, 2014 at 04:57:01pm
Hey Guys,
29th Jun, 2014 at 05:04:27pm
Those look like really expensive air line fittings. Personally, I just pull the hose off and plug it with a bolt or screwdriver. On 26th Jan, 2012 Tom Fenton said:
29th Jun, 2014 at 06:24:15pm
My BMW road bike had these as standard which meant that taking the fuel tank off was a simple operation without faff.
29th Jun, 2014 at 06:40:50pm
Any of the typical braided style hose suppliers sell them.
29th Jun, 2014 at 07:01:14pm
Guess it is quite expensive! I wouldn't say it is such a massive problem but after taking the carb off twice and the fuel pump three times it was getting on my nerves a bit!
29th Jun, 2014 at 07:59:16pm
In the think automotive catalogue the 1/4 inch dry break connectors are listed at around 40 quid per hose. Think I will give them a call tomorrow. |
![]() 293 Posts Member #: 10010 Senior Member Northants |
30th Jun, 2014 at 03:44:28pm
I worked on an F1 fuel system last year, and they use quick disconnect fittings between the fuel tank and engine, if I remember correctly they were AN -6 size, staubli, they were pretty reliable and only ones that had any issues were the ones that were disconnecting accidentally at 120+DegC and 200Bar in the hydraulic systems. If you have them after the pump you should be alright, as generally your fuel pump will be able to supply more pressure than required anyway. |
