| Home > Help Needed / General Tech Chat > Takeoff on carb | |||||||
![]() 330 Posts Member #: 9628 Senior Member |
1st Jul, 2014 at 11:11:06am
whats this take off for on the carb?
1st Jul, 2014 at 11:21:47am
Vacuum take-off for the dizzy. Blank it off. If something is worth doing, it's worth doing half of. |
1st Jul, 2014 at 11:51:24am
Or plug it back into the dizzy:) I run a supercharger and I don't care the TB is on the wrong side.
1st Jul, 2014 at 11:58:32am
True, I am assuming mega jolt If something is worth doing, it's worth doing half of. |
1st Jul, 2014 at 12:54:08pm
Would you use it for megajolt anyway or is there a better place for the takeoff? On 26th Jan, 2012 Tom Fenton said:
1st Jul, 2014 at 01:13:21pm
I found that the signal was really weak when I tried to use it for Megajolt. Much better signal off the manifold. If something is worth doing, it's worth doing half of. |
1st Jul, 2014 at 05:35:31pm
It's the wrong side of the butterfly for MJ. In the 13's at last!.. Just |
1st Jul, 2014 at 05:35:48pm
I believe... In the 13's at last!.. Just |
1st Jul, 2014 at 07:23:37pm
the butterfly interferes with it, without checking i think it is on the wrong side at idle but soon swaps side at part throttle giving alot more vacuum at part throttle
Yes i moved to the darkside |
1st Jul, 2014 at 08:16:17pm
Fair enough, it is useful for anything else? boost gauge maybe? On 26th Jan, 2012 Tom Fenton said:
1st Jul, 2014 at 08:24:11pm
Yeah I've blanked it off now :)
1st Jul, 2014 at 08:28:00pm
Could do but it doesn't show good vacuum in my experience. If something is worth doing, it's worth doing half of. |
1st Jul, 2014 at 08:39:59pm
On 1st Jul, 2014 Carlzilla said:
Fair enough, it is useful for anything else? boost gauge maybe? No. You need to take this directly from the manifold. In the 13's at last!.. Just |
1st Jul, 2014 at 08:42:10pm
Fair enough, cheers Gary. Just seems a shame to not be able to use it. On 26th Jan, 2012 Tom Fenton said:
1st Jul, 2014 at 08:58:46pm
nope not much use for it Yes i moved to the darkside |
