| Home > Help Needed / General Tech Chat > Mirage | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
14th Jan, 2004 at 10:28:55pm
Hi, this is a question mainly for the mirage crew but help from all would be good, I have found a metro turbo engine, which will go in a pickup when i find it, mainy people have said i should go for a t2 convertion and i don't really want to cut the bulk head, so the mirage kit seems the way to go, i want to talk spec, i plan to renew all the general things in the engine, i want to get about 120bhp on standerd boost with the option to turn it up to get more when i need it, what do you serject doing to the engine spec, things like crank, cam and other sorts of things please help. |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
16th Jan, 2004 at 07:54:26am
alright alex, if you get any feedback from mirage i'd be interested in what they have to say, any chance on forwarding to me?
16th Jan, 2004 at 01:56:50pm
if by120hp with 'standard boost' you mean 7psi? - i think you'll be only achieve this with a highish CR, and some serious head and cam work... It does depend which RR you take it to to get your '120hp' however...........
17th Jan, 2004 at 05:19:50pm
yeah i ment 120bhp with a good amount of bost not at a point where it will kill the engine quick. 10psi sounds about right, what could it be turned up to safely?
17th Jan, 2004 at 05:56:20pm
how long is a piece of string...
AlexF |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
17th Jan, 2004 at 07:45:45pm
I'm getting asked this all the time (fingers getting tired typing !!), so i think its about time i did a bit of an article on it. I'll try and put something together over the weekend. It really is a bit tricky though as you all have different budgets and power expectations. I'll see what i can do.
17th Jan, 2004 at 10:35:07pm
so if i take a standerd metro turbo engine, and fit the mirage kit, with a intercooler, and cam, rockers and a head, that will do the trick very nicly? does the kit come with the coolent pipes for the t2, or would i have to work that all out? do i use the mini turbo down pipe from the turbo or does the kit come with something one? i will call you when i get the car and engine and the engine work starts which will be april time, i just want to know im looking at the right way to go. thanks Alex. |
17th Jan, 2004 at 10:36:29pm
sorry just thought, when i say head i mean a ported low compression fancy head, and 1.5 rockers and a decent turbo cam what ever soute the engine. |
195 Posts Member #: 26 Advanced Member Cannock |
18th Jan, 2004 at 09:18:02am
Alex I have asked for more or less the same spec as you so i will do my best to answer the qustions for you.
