Home > General Chat > Fuel outlet restrictions - share your views
Billus89
Member #: 8931
Just having a new tank made and I am going to be using 8mm send and 8mm return outlets on the tank. Will this be ok???
I know people say the rule of thumb is to use larger return, i.e. 8mm send and 10mm return, but the outlet on the pressure regulator is 8mm, and this is surely the maximum that can be sent? Even if I used an adapter from 8mm to 10mm on the return line, this will still cause the same restriction?
Who is using 8mm on both lines? What/if any are your issues?
Please share your views,
Billus89
tadge44
Member #: 2500
Buckinghamshire
8mm for both feed and return with no problems whatever
Van had a 6mm (at best) feed and an 8mm return, no issues.
8mm will be fine.
But if I were you I'd check what size inlet your pump is. They can be 12mm. If you have a 12mm outlet it'll make the plumbing easier and neater.
as wil says, the bosch pump and the such have about a 1/2inch inlet
i had a problem with 8mm feed and return but i think that was more down to the return being 'T' into the fuel pump inlet
ive run 8/8 and 10/10 no problems
Billus89
Member #: 8931
Thanks for the info guys, and good point Will!!!
Cheers, billus89
