Home > Help Needed / General Tech Chat > will my crank sensor work like this?
coopdog
Member #: 9628
will it pick up a signal?
Put it perfectly in line. Best to do it before you have any problems.
oli79
Member #: 8480
No it won't, and if its the trigger wheels bracket I had the same problem, time to file
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
coopdog
Member #: 9628
ahhh whattt
I also set mine to 1mm between the sensor and the wheel
I am thinking no
cant quite tell the angle, but it looks fooking way off lol
It looks too high as well, unless it's just the angle of the shot?
all as the gents say above!
coopdog
Member #: 9628
all sorted now :)
