| Home > Help Needed / General Tech Chat > Smoking | |||||||
3rd Jul, 2014 at 06:57:22am
I,m getting well choked with my van engine as it still smokes after a second rebuild.
3rd Jul, 2014 at 07:26:07am
Try it NA to eliminate the turbo? If something is worth doing, it's worth doing half of. |
3rd Jul, 2014 at 07:30:02am
pull off the oil feed to the turbo david ,pop it in the rocker box or in a bucket ,and run the car for a little while on tickover to see if it stops smoking . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Jul, 2014 at 07:36:57am
Have you drove it yet? Sometimes they will smoke a little until they bed in 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
3rd Jul, 2014 at 09:41:33pm
I will try what Robert suggests and I have considered the NA test but it is a bit of a PITA to make a new exhaust to fit the NA manifold.
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
4th Jul, 2014 at 08:18:00am
What oil pressure you using? Is it a GT1752? I found anything over 60psi passed oil through the seals into the compressor housing . Edited by alaskanow0 on 4th Jul, 2014. Class C 3rd Place Avon 2011 14.18 @101mph |
4th Jul, 2014 at 10:06:41am
That sounds as if it could be my problem then.
4th Jul, 2014 at 11:38:17am
your max pressure should not really effect idle pressure david , since the bypass valve should be closed .
4th Jul, 2014 at 05:05:07pm
Yes that way too high for the GT1752. This is a known problem on the Saab forums. Turned mine down to 50psi cold & 25psi hot idle. Cruising and boost is normally between 35-45psi. Works a treat. Edited by alaskanow0 on 4th Jul, 2014. Class C 3rd Place Avon 2011 14.18 @101mph |
4th Jul, 2014 at 08:39:10pm
shorten the overload spring a tad dave,
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
4th Jul, 2014 at 09:16:30pm
Had a variable relief valve on for years,set to 55psi cold,really to help with oil leaking out the midget rear seal,but sounds like it has helped with this problem a well.
'Where does the engine go?' |
5th Jul, 2014 at 01:15:58am
Steve, it starts up fine and then let it warm a little and the "haze" starts to appear - rev it and it gets a lot worse. |
5th Jul, 2014 at 08:24:57pm
When I had a smoking problem a while back,which was fine on startup but got rapidly worse on warm up it turned out to be oil leaking down the parent bore of one guide.The leak only started when there was enough oil of low enough viscosity sitting in the valve spring pockets. I found the leakage by leaving thin oil sitting overnight in the pockets and checking in the ports.Peter Burgess found the root cause and fixed it by reaming the guide parent bore and fitting a new oversized OD guide. 'Where does the engine go?' |
5th Jul, 2014 at 08:27:55pm
Sorry should also have said that if it's smoking at idle oil pressure is too low to overcome turbo oil seals. 'Where does the engine go?' |
6th Jul, 2014 at 06:44:10am
Oil pressure at idle when just started is around 80 psi !
