Home > Help Needed / General Tech Chat > standard hif44 - turbo hif44
rattydriver
Member #: 10808
leicester
Hi, need some advice, I've got an hif44 carb and want to know what the difference is to a
Turbo one... will a Turbo rebuild kit and needle / jet be enough to use it with my turbo build..
Any advise appreciated...,
Or has anyone got a Good turbo carb for sale
On 24th Oct, 2012 Brett said:
yes piece of piss
in fact the hardest part is searching
I just searced 'convert carb' and got a page full of replys I have even posted pictures and a description some where on how too.
Edited by Brett on 4th Jul, 2014.
rattydriver
Member #: 10808
leicester
I have had a search did find a thread but it wasn't about converting just refurb.... I'll have another look.
rattydriver
Member #: 10808
leicester
Convert carb . Came back as not found
Rammie2000
Member #: 10190
belgium
Just type hif44 and you'll get all you bargain for. Worked for me.
jakejakejake1
Member #: 10010
Northants
If you are having trouble searching the forum, use Google, and put site:turbominis.co.uk before the term you are searching for
Like this: http://bit.ly/1qVtR9B
lee.pb
Member #: 9199
Lancashire
There are a few suttle changes but nothing major.
1. throttle linkage is on the opposite side.
2. throttle spindle seals are installed to opposite way
3. there is a seal under the dash pot.
4. there is an additional air way from the intake to the float bowl, to pressurise it on boost.
Its simple to convert Ratty.
