Page: |
Home > Non-Mini Projects > motorcycle trouble. | |||||||
1750 Posts Member #: 10190 Post Whore belgium |
5th Jul, 2014 at 11:09:38am
Shadow vid: http://youtu.be/0zcsNmsrPtk
6743 Posts Member #: 828 Post Whore uranus |
5th Jul, 2014 at 03:45:49pm
private video rammie ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Jul, 2014 at 04:48:41pm
yes just reset it normaly should work now
Edited by Rammie2000 on 5th Jul, 2014. you can do anything if you set your mind to it...
5th Jul, 2014 at 08:03:42pm
blocked fuel filter in tank ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Jul, 2014 at 08:27:34pm
that should be cleaned by the shop. will look in to it. noticed now that the rear cilinder sparkplugs have a very weak spark ( yellow) maybe it is that it cant burn its fuel proper? you can do anything if you set your mind to it...
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
5th Jul, 2014 at 08:39:20pm
On 5th Jul, 2014 Rammie2000 said:
that should be cleaned by the shop. will look in to it. noticed now that the rear cilinder sparkplugs have a very weak spark ( yellow) maybe it is that it cant burn its fuel proper? theres the problem, coil goosed and also change the glazed plugs.
5th Jul, 2014 at 08:52:24pm
i was thincking of a test. take a blok of wood drill a hole in the centre and to nails that meet in the centre hole spaced 7 mm of each other. 1 side connected to the spark lead and the other to an earth point... spark should jump right? you can do anything if you set your mind to it...
6th Jul, 2014 at 01:19:56pm
So i made that thing with 2 screws in it spaced 8 mm out of each other. The sparks went from one point to another without a problem and were nice and bleu. Do i may presume that it are only the sparkplugs that are worn out? Since some of those give a more yellow spark. you can do anything if you set your mind to it...
328 Posts Member #: 9107 Senior Member Devon |
6th Jul, 2014 at 07:00:48pm
I have experienced this before on my bike , it turned out to be knackered plugs , worked fine in a test but once under strain e.g high revs they couldn't keep a decent spark . Not saying this is the solution but it could be a possibility |
6th Jul, 2014 at 09:26:22pm
i'll get some new ones tomorrow. needs new ones annyway. you can do anything if you set your mind to it...
9th Jul, 2014 at 07:28:31pm
so got the new sparkplugs in ( garage had put in different plugs for each cilinder. ) also screwed the pilot screw out and gave it a light rub but the bike does not perform anny better. guess shop did a bad job cleaning the carbs
Edited by Rammie2000 on 9th Jul, 2014. you can do anything if you set your mind to it...
9th Jul, 2014 at 08:03:33pm
does the choke make any difference rammie ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Jul, 2014 at 10:24:58pm
On 9th Jul, 2014 robert said:
does the choke make any difference rammie ? nope. in fact it makes it slightly worse you can do anything if you set your mind to it...
10th Jul, 2014 at 02:55:46am
blocked jets in the carbs ?I know my bike if left for a while gets a really gritty deposit in th carbs and it blocks the idle jets to the point where it won't tickover , its quite tough to get out of the jet too . ,maybe they missed the mains or something . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Jul, 2014 at 06:59:34am
Crap. Its more crowded in there than under the bonnet of a vtec mini.... you can do anything if you set your mind to it...
10th Jul, 2014 at 01:47:32pm
https://www.youtube.com/watch?v=RZjAzUgZYGk
17th Jul, 2014 at 09:12:43pm
Edited by Rammie2000 on 17th Jul, 2014. you can do anything if you set your mind to it...
17th Jul, 2014 at 09:13:53pm
18th Jul, 2014 at 05:18:42am
hmmm, some of the jets can be a bit difficult to clean ramie , are you sure all the jets in the front carbs are clear ? also is the air filter stock ..and no air leaks in the pipes to the carbs . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th Jul, 2014 at 10:35:25pm
Old / bad HT leads? I replaced my old ones after similar problems. I was convinced it was a fuelling problem but was just luck that I saw an arc from the lead to the front cylinder. Edited by PhilR on 20th Jul, 2014. |
21st Jul, 2014 at 09:40:58am
Pretty sure unscrewed them all for cleaning. Tought about air leaks... how to test? Ht leads are original from 97 but only have 8000miles. Stock airfilter but brand new. you can do anything if you set your mind to it...
21st Jul, 2014 at 11:44:47am
15+ years is quite a long time for the leads. My HT leads we're also original from 1995 Resistance was fine, but plastic insulation was starting to age harden. Only had to replace the wire as the ends are screw on. Even if they still ok now, they are a serviceable part and they'll fail at some point, so for a few euros I'd change em. Edited by PhilR on 21st Jul, 2014. |
21st Jul, 2014 at 03:17:24pm
what about air jets and other jets in the body of the carbs ? didi you unscrew the idle mixture screws and bast carb cleaner dow the orifices ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
15th Aug, 2014 at 08:43:44pm
so update. new leads in (resistance on the old were still good) but the same trouble. carbs open again i i seen that the needle valve sticks up a bit when the ( dont know the word) plastik thing that gos up and down with the fuel) is not attached. ordered some repair kits for them. i'm pretty sure now its al down to the carbs.
16th Aug, 2014 at 07:50:39am
orifices are holes , when you unscrew the idle adjusting screws you are looking at a threaded hole ,spray the carb vleaner down it , it should come out of the little hole inside the bore of the carb ,somewhere near the butterfly .also it may come out of a hole at the inlet , block this with your finger to make sure it cleans the inner hole . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
Page: |
