Home > Help Needed / General Tech Chat > metty 4 pots....
nutter driver
Member #: 47
Not very sunny swanage
quick question, dragged a set of these off a car in the scrapy the other day, basically wondering the best way to fit them to the mini....
i have seen a few ways of doing it (eg all the metty stuff, then fitting -ve camber bottom arms etc to get it true again), but am i right in saying the best way is to fit the metty disc and caliper to the mini hub, (using era bolts, and the right hoses etc)???? do i need to use the metro drive flange? i know your supposed to take off the locating lugs etc, which is no problem. but do you actually need to use the metty flange rather then the mini one? i have noticed they are slightly different thicknesses, but i am not sure whether it is needed or not....
sorry for asking a question on the most common mod on minis, but there seems to be so much conflicting info about out there, and im buggered if i want to take a chance on something as important as brakes!!!!!
cheers peeps.
Pete
Nick
Member #: 154
Midlands
use the metro drive flange and as you say machine the lugs off, its that simple :)
and yup you're right, the best way to fit em is to the mini hubs.
turbo hogster
Member #: 178
stowmaket suffolk
done mine that way, you need the mety flanges because if they are vented the dimensions are different.
dont go mad at first on pads just use a good set of mintex say and go from there.
i havnt faded mine yet.
Ive used the metro hub assebly in the past, and no matter what adjustments I made the steering was always 'loose' and 'light' and basically rubbish. I didnt trust the front end grip at all.
snowfruit
Member #: 557
Ireland
I've got the original disv set up (8.4" i believe) that should do for a moderate turbo right? (running 12" possibly 13"s eventually)...
