| Home > Help Needed / General Tech Chat > ballast non ballast 12 v ballast? | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
6th Jul, 2014 at 11:46:48am
i have placed a electronic dizzy ( comming out a '91 1275engine with the module on the side) in a 998 mini to get rid of the contact breaker points. now the mini had a coil running on 12 v ( straight from the fuse box so not the pinck/white resistor wire) and it is running that coil for years on that old distributer.
6th Jul, 2014 at 12:00:14pm
For electronic ignition you want a non ballast coil and a 12v feed. Replace the pink/white with just a similar sized length of wire to remove the resistance and then fit a non ballast coil. On 26th Jan, 2012 Tom Fenton said:
6th Jul, 2014 at 12:04:57pm
Also we went on a 30 mile run recently, one of the cars there had an electronic distributor and a ballast feed and coil, the car broke down, I tried to help diagnose the problem to find there was no spark, checked the points to find out is was a replacement electronic kit and then felt the coil, it was ridiculously hot and had obviously burned out. On 26th Jan, 2012 Tom Fenton said:
6th Jul, 2014 at 01:15:47pm
The pink and white has been removed an replaced ages ago. Like said it runs a 12 v feed straight from the fusebox. And thats what I'm afraid of. Burning out that coil. But since it ran 12 v for years now ( on that ballasted lucas with points) im not sure if that means it will keep on running on that non ballasted electronic one... you can do anything if you set your mind to it...
6th Jul, 2014 at 04:45:51pm
If the coil is a non ballast one, it will be fine. I ran a ballast coil with a ballasted feed and coupled to a britpart 45d electronic points replacement kit, and it worked beautifully with absolutely no reliability issues. I wouldn't mix a non ballast feed with a ballast coil or the other way around though. On 26th Jan, 2012 Tom Fenton said:
6th Jul, 2014 at 05:44:10pm
But when you know if its ballast non ballast etc. you can do anything if you set your mind to it...
6th Jul, 2014 at 06:09:34pm
I can't remember the source of info but you can measure the resistance of the coil to find out if it's ballast or non ballast. Could have been a youtube vid! On 26th Jan, 2012 Tom Fenton said:
174 Posts Member #: 9128 Advanced Member |
6th Jul, 2014 at 07:46:11pm
You want a DLB198 |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
6th Jul, 2014 at 08:06:22pm
I ran a non-ballast coil on a ballast supply for a long time without realising when I swapped my standard 998 A+ coil for a 1275 gold coil that I was given. I noticed one day that the coil was getting red hot! Which I now understand is the main symptom of having the wrong type of coil in use on a ballast supply.
6th Jul, 2014 at 09:29:00pm
i found on the web that 3 ohm is an electro coil and 1 to 1.5 ohm should be a ballast coil. i have 3.6 ohm you can do anything if you set your mind to it...
