Home > Help Needed / General Tech Chat > Minispares ultralight steel flywheel
dion
Member #: 9169
Cape Town, South Africa
I recently purchased one of these flywheels only to discover when it arrived it was a inertia start not a pre engaged one, this was my mistake...*frown*
Now from what I read on here the inertia and pre engaged minispares ultra light flywheels are the same except for the ring gear? And all I need to is get the correct inertia starter and do the necessary wiring to make it work?
I'm a little far away from minispares so returning it is not an option.
Advice appreciated, thanks
Rammie2000
Member #: 10190
belgium
you can just put on a different starter motor but you need to do some rewiring. ( take an pre engaged and an inerta wire diagram and youll see what needs to be changed. also will need a separate starter relay
It's easy enough fitting an inertia starter and solenoid as I did for an engine swap, but as it's a brand new flywheel you're probably better off ordering the preengaged ring gear and getting it fitted.
Or use the one off your standard flywheel
dion
Member #: 9169
I think I'll just get a new starter, thanks for the replies
