| Home > Help Needed / General Tech Chat > Starter Motors and Starting! | |||||||
6th Jul, 2014 at 10:26:49pm
Right guys this is a bit of a two pronged question. Car is now running, driving and completed a 150mile road test today without any major problems. Biggest problem i do have its its an absolute bitch to start especially when hot.
7th Jul, 2014 at 09:30:37pm
bad earth ??
8th Jul, 2014 at 03:21:05am
It's a NA motor at 10.5:1 so reasonably high compression. The starter never struggled on the standard motor so don't think there's anything wrong with it as such. It's just not up to the job.
8th Jul, 2014 at 05:52:30am
The coolant temp and cranking tables are multipliers of your base fuel and ignition map, so be very careful with them.
8th Jul, 2014 at 12:06:33pm
The coolant temp table is really for cold starting not hot starting. You need to concentrate on the cranking table. http://www.twin-turbo.co.uk
8th Jul, 2014 at 04:48:00pm
I think ive got it now. There is only the one table for cranking. It shows Crank Counts along the top and temp ranges down the side. Im assuming to adjust your hot starting you just alter the count in the 80-100C range and your cold starting the 10-20C range etc.. I assume the number in the box is a multiplication of the base map, not too sure, but it is clear that the higher the number the more fuel it puts in!
8th Jul, 2014 at 09:00:50pm
Yes, the cranking table is a multiplier of the base fuel map. Haven't messed with the ignition side too much so can't really comment on that. On 11th Feb, 2015 robert said:
