Home > Help Needed / General Tech Chat > AFR Guage
coopdog
Member #: 9628
i know it should be around 14.7 at idle
but what should i be looking for before it starts causing damage?
14.7 at idle,
about 12-12.5 under power, you dont want any less than about 13 really,
at cruise, aim for around 17
coopdog
Member #: 9628
nice and straight to the point :L
thanks mate
D4VE
Member #: 10749
lowestoft suffolk
On full chat mine sometimes can flick down to 11 is that a no no? (P.s i havent driven the mini for over a month now so i think i mean 11)
Nothing gets past Dave lol
yeah 11 is ok, and safe, but you can get to a point where you start compromising bore lubrication, dunno how far you have to go for that though.
Most older turbo jap stuff is mapped to run 10afr on full boost leaning this out to 12afr does pull some decent power gains on its own or stuffing more boost in and keeping same fueling
D4VE
Member #: 10749
lowestoft suffolk
Thanks joe, the guy who built it and set it up said he'd rather it lil rich than weak, 11 has only been seen when foot is to floor and its at the point of pop or poop myself lol
coopdog
Member #: 9628
so lower the number the leaner it is?
No low = rich
D4VE
Member #: 10749
lowestoft suffolk
Was waiting for someone to answer first to make sure lol lower = rich
yep AFR is air to fuel by weight,
so 17:1 is 17 parts air to 1 part fuel
and 10:1 is 10 parts air to 1 part fuel
Sean1
Member #: 10798
running at 17 is far too lean for my liking 14.7 is perfect afr it will go down with your right foot lol
maybe for your liking but if the engine will cruise at that and temps stay in check and there is no det that this is perfect for good fuel economy
mine wouldnt go quite that lean without a steady misfire but 15.5 - 16afr at a steady 60mph it was more than happy at
14.7 is perfectl
technically yes but its not the best afr for max power or peak torque in either N/A or turbo so it may not be a perfect as it seems in terms of anything usefull IMO
