| Home > Help Needed / General Tech Chat > Verto Clutch stops dead on engaging (any ideas) | |||||||
10th Jul, 2014 at 07:12:20pm
Any ideas on the following? Before I investigate tomorrow.
10th Jul, 2014 at 08:33:35pm
I take the throwout nuts aren't loose and haven't wound themselves tight to the case? |
10th Jul, 2014 at 08:37:40pm
10th Jul, 2014 at 08:45:17pm
Thats a good call too |
10th Jul, 2014 at 09:19:53pm
No, throw ours are all good don't touch the casing.
10th Jul, 2014 at 09:25:45pm
Something binding on the pedal linkage?
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
10th Jul, 2014 at 10:39:03pm
Make sure the flywheel isn't loose, had mine fall off a while back, pedal went solid. On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
11th Jul, 2014 at 11:01:34am
On 10th Jul, 2014 1293 sprite said:
Make sure the flywheel isn't loose, had mine fall off a while back, pedal went solid. That'll be it then! Lock tabs just spun and the bolts worked it's way out. Bastard! |
11th Jul, 2014 at 05:44:28pm
Hope your crank taper is ok, mine wasn't, but then again I was doing about 50mph at the time... On 25th Sep, 2009 mini13 said:
11th Jul, 2014 at 05:49:34pm
It's not ok, probably not as bad as it happening at 50 though!
11th Jul, 2014 at 06:16:50pm
I just knocked it down too leaving a dual carriageway, into 3rd, then it started clattering.
11th Jul, 2014 at 09:30:51pm
The hub looked worse than the crank.
