Home > Help Needed / General Tech Chat > missing engine
coopdog
Member #: 9628
ive just finished my turbo build and when i start it its missing
i think its really rich because when i took the plugs out they were black and the car has only ran for a couple of mins because i cant drive it off the driveway because alod of scaffoling in the way.
would it miss if its too rich??
also whats the correct way to lower the mixture at idle do you have to lower the fuel pressure?
thanks
Have a look into basic carb setting up, as long as the base fuel pressure is 3-4psi then it's just a matter of messing around with settings until it runs well on idle. If it's on choke or rich it's going to turn the plugs black anyway, especially if it's only run for a couple minutes.
I'd look a different place. Searched in the garage??
wng691s clubby
Member #: 9252
Cleethorpes
its not under a cover is it ?
Done now needs redoing lol
You may have killed a plug.
With the other posts you were making about your nodiz, are you sure it's actually working now.
Also, as John says, a plug (or more than one) may be dead especially if you were trying to run it with defective ignition.
Nowadays it seems common for plugs to be killed once they have been fouled and no amount of cleaning seems to recover them. Don't know why, pronbaly all the additives in modern petrol, but I've had it happen and a few others on here have mentioned it.
Nick warwick
Member #: 8926
Sheffield
I noticed on your video you tagged me in mate that your AFR was reading very high and beyond its reading. Looked like you could be running way way too lean so be careful! get that back down to around 12-13 or around that
Edited by Nick warwick on 14th Jul, 2014.
coopdog
Member #: 9628
i couldnt get it to tick over by itself as i only ran it see if it would start and it did then i pretty much turned it off.
bit it is rich it fucking stinks of petrol haha
will report back friday to see if it runs.
can i change the mixture on the sealed su? i now on the normal ones you have the nut at the bottom
coopdog
Member #: 9628
yeah when i ran it the other day it stopped missing and was fine.
but this is with out the choke and the fast tickover and a cold engine as it only ran for about 30 secs
There is a mixture screw at the back of the carb, as I said look into basic carb setting up info on the net.
coopdog
Member #: 9628
ahh what i never notice that.
yeah i know how to set up the carb will get that sorted *happy* thanks
coopdog
Member #: 9628
also just found this haha
