| Home > Help Needed / General Tech Chat > converting from servo to non servo | |||||||
57 Posts Member #: 9625 Advanced Member |
15th Jul, 2014 at 06:32:42pm
Hey guys , my servo is giving me hassel I think one of the diaphragms has got a hole or split in it . Now I was wondering can you convert from servo to non servo without changing the pedal box , im sure ive read of someone on here doing it I think they may have made a push for the pin that connects the rod to the pedal , any help would be great |
15th Jul, 2014 at 06:46:46pm
I believe you can but it's a ballache. I rebuilt my servo, it wasn't easy getting it apart and less easy putting it back together! On 26th Jan, 2012 Tom Fenton said:
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
15th Jul, 2014 at 06:47:11pm
Glad you asked.. wanting to know the same, plus differences in pedals in the pedal boxes? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
15th Jul, 2014 at 06:50:16pm
You can just change the brake pedal. It's probably not a nice job and no easier than swapping the whole box. In the 13's at last!.. Just |
15th Jul, 2014 at 06:52:54pm
So the brake pedal itself is a different shape/size? I have a few boxes but cant tell the difference? On 24th Oct, 2015 jonny f said:
![]() 324 Posts Member #: 9441 Senior Member South Devon |
15th Jul, 2014 at 07:09:21pm
I know the hole clevis pin hole in the servo pedal box is certainly bigger. I think the ratio is different as well.
15th Jul, 2014 at 07:30:19pm
The hole the clevis pin goes through is bigger and higher up on the servo pedal box.
15th Jul, 2014 at 08:06:35pm
Ive messed around stripping 3 boxes having a play n putting a few holes in On 24th Oct, 2015 jonny f said:
15th Jul, 2014 at 08:58:36pm
I've bushed one and was about to do another.
15th Jul, 2014 at 09:15:09pm
Cheers for the reply guys |
14th Sep, 2014 at 12:14:14pm
On 15th Jul, 2014 Paul S said:
I've bushed one and was about to do another. However, the above comments about ratio and hole position have rang alarm bells, so I'm going to have a detailed look at servo and non-servo pedals before recommending it to anyone else. Right, bushing the pedal does not work
We've been having sticky brakes on the Mini 30. Tried to get to Stanford Hall in it this morning and had to turn back and go in another car. A quick trawl through the parts bins at Stanford reveals that the pedals are different and the hole is in a different position. I'm guessing that the servo brake pedal does not allow the piston in the "yellow tag" master cylinder to drop far enough to release pressure. We now have another pedal box
