| Home > Help Needed / General Tech Chat > Turbo on the way - some more questions though | |||||||
![]() 321 Posts Member #: 557 Senior Member Ireland |
8th Aug, 2005 at 06:42:06pm
Right after much brain picking (thank you all) most of the main parts needed for my 998 turbo are in the bag or on their way. I now have a GT15 turbo and the intercooler, carb & plenum, EDIS and 12G295 head are all in the post. I'll be heading down to my local forge soon to see if they can do any pipes for me and I'm sourcing parts for a MegaJolt. |
8th Aug, 2005 at 07:04:50pm
You will need a custon exhaust manifold to suit your turbo. You may be able to adapt a metro turbo manifold to suit, I don't know. But an LCB is no use whatsoever. The turbo needs to bolt to the manifold, and the manifold needs to be sturdy, as it will have to support the weight of the turbo. You will then need to make a downpipe to fit to your turbo.
8th Aug, 2005 at 07:22:42pm
Yes I forgot about the regulator and pump but I already have a metro turbo fuel pump although I think I may ditch it in favour of an SPI fuel tank. and I can get a regulator from Mini spares for about £10 i think.
8th Aug, 2005 at 07:24:31pm
Oh now I think about it, can I even use a Metro turbo inlet manifold on a 12g295 head...? |
8th Aug, 2005 at 07:38:40pm
I don't think you will get the correct rising rate fuel regulator for a tenner from Minispares.
9th Aug, 2005 at 10:16:37am
Okay the fuel regulator is actually £33
9th Aug, 2005 at 10:18:59am
10+psi boost on standard 998 bottom end??????
9th Aug, 2005 at 11:41:04am
It would be the pistons I would worry about personally.
9th Aug, 2005 at 12:03:19pm
Hmm timing chain - would hardly like that to break on me. Thanks mini1071s
9th Aug, 2005 at 12:08:02pm
Can't make any recommendation as I've never turbo'd a 998.
9th Aug, 2005 at 12:17:15pm
I've had two sets of pistons in the engine:
9th Aug, 2005 at 12:46:39pm
The slipper pistons were pretty standard pistons. The only reason they broke was we were running 18psi. They had run for some time in the engine, just at lower boost. http://www.twin-turbo.co.uk
9th Aug, 2005 at 01:03:27pm
Will my standard pistons survive for a reasonable amount of time?
9th Aug, 2005 at 02:03:59pm
Does anyone - possibly will or ben as you have a 998 - have any pictures of an exhaust manifold and turbo? I think this is the only area I'm a little unsure of as yet.
9th Aug, 2005 at 02:17:29pm
We just use the standard metro turbo exhaust and inlet manifold. It will all fit. http://www.twin-turbo.co.uk
9th Aug, 2005 at 02:29:19pm
What sort of adaptions did you need to fit the turbo/downpipe? |
9th Aug, 2005 at 02:36:49pm
We use a T3 so all the bits are off the shelf.
