Home > Help Needed / General Tech Chat > Diff side cover bush/pot joint running clearance?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
as above ive pressed new bushings into the side covers where the pot joints go in but cant find the running clearance spec?
my new pot joints measure 31.790mm not sure on the running/oil clearance that should exist?
graemec
Member #: 1424
Carnforth, Lancs
31.5mm according to this:
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
appreciate the help but the new pot joint measures 31.790mm so 31.5mm is not right
im thinking it only need a tho or two as its not really a high speed item and its at least partly submerged in the sump so lube should be fairly decant id think?
for instance the pot joint is turning the wheel rpm probably some where in the 2000-3000rpm range? might calculate it later
