Home > Help Needed / General Tech Chat > Vizard hif38, or just get a 44?
Just debating this for my engine build, im hoping to get around 90hp from my temporary (not sure how long for, probably a while) engine. In vizards book he reckons the mods can produce results of the carb the next size up, but looking at flow figures he recommends 2cfm per hp. So I would want a carb to flow 180cfm in effect, but the 1 1/2 carb would only see around 160cfm at an educated guess. Can't find any figures for a bog standard hif44. Is this CFM all just balls and the 38 with mods will be up to the job or should I just sack the idea of the modded 38 off now and not waste my time? I do have a 44 turbo but I'd rather save this for the proper engine build tbh.
Edited by Carlzilla on 22nd Jul, 2014.
Rammie2000
Member #: 10190
belgium
I have vizard moded a38 long time ago to the extreme. ( half spindle and so on) it gives a difference but still i do feel like a mild modded 44 gives much much more hi end grunt. Yet if you don't want to use the 44 and don't want to buy one it is up for the job.
viz139
Member #: 9182
I swaped a standard HIF38 to a std HIF44 on a std '94 1275 with LCB and exhaust and the differance was huge. Engine reved a lot easier and thats a lot less hp than your looking at. Don't forget the 44 also has a larger jet so more fuel is possable.
