Home > Help Needed / General Tech Chat > swappin roofs... can it be possible?
D4VE
Member #: 10749
lowestoft suffolk
As the title.... i know what it takes to remove a skin, but can it done neat enough to reuse on another mini and vise versa.. ill quickly explain.. i have a gt with webasto and a mayfair with good roof... wanted to know if its possible to do it neat enough to swap skins?
Nothing gets past Dave lol
I know people who have reused skins but it was not the neatest job. They used an old roof and removed the frame from the skin then spot welded it but they weren't the most careful when removing the frame and damaged the skin in a few places
Not sure from your statement if you are trying to swap the skins between cars?
Callum
Member #: 10396
Stoke-on-Trent
Arn't the roofs roll welded? Would take some neat drilling to reuse them!
viz139
Member #: 9182
I cut an A pillar and roof corner off a car and then seperated it to repair an A pillar on another car . The gutter is roll welded and was impossable to seperate without ruining the lip on the roof. I have fitted 2 webastos ,not the easiest to mark out on a curved roof. I would never do one on someone elses car.
I just put a lot of spot welds into my replacement skin. It's not dropped of yet.
If you cut the roof of just below the gutter and then clean off the lip with a flap disk it should be ok.
If you turn the scrap shell on its side to improve access to drill out from the bottom it should be doable, or just cut it at the a pillers. Lot of hassle though!
D4VE
Member #: 10749
lowestoft suffolk
Ok thanks fellas, how much are new metal roof skins now days? Last time i checked they were about £250?
About £300 i think
Ouch, £350. Best getting a roof off another shell http://minispares.com/product/Classic/Body.../roof.aspx|Back to search
yep i did it, and fitted fitted it to my mk1. it was too bad. the worst job was cleaning up the lip of the old already to fit. but in all honesty it was an easier job than trying to clcan up the old wells off the car. i spot welded mine in every 10-15mm or so then rabid a bead if sealant around the edge. its been fine for the last 3 years like that.
D4VE
Member #: 10749
lowestoft suffolk
Ah ok so swapping roofs between 2 minis is a bit of a no due to wrecking the side u dont want? Fibreglass skins still around £100? And anyone fitted one with just bolts/fastenings so its removeable?
I fitted one and just tiger sealed it on, never had a problem and you'd never be able to get it off again haha
its easy enough to take a roof off to reuse on another mini. but the only way to remove it is to cut it off below the gutter and grind the excess bits off. unless your going down the convertible route with the donor car definitely a no goer.
Quicksilver-ash
Member #: 10905
Barnsley, whippetshire
Is it just to repair the webasto hole? If so just stick a carbon roof on.
D4VE
Member #: 10749
lowestoft suffolk
No its because the one with the webasto i would want as a daily drive so would prefer all steel roof
viz139
Member #: 9182
Bond it over the steel roof ,it would be as strong as the webasto.
