| Home > Help Needed / General Tech Chat > Radius arm stub axle/castle nut thread size r/h thread. | |||||||
27th Jul, 2014 at 01:44:47pm
So my old stub axle was knackered, so replaced it with a new r/h threaded one and bought a new washer and nut to fit. Threaded the nut on a little by hand, and it was a smidge tight a bit like front driveshaft nuts, so I preceded to get the ratchet out with light pressure and it stopped not far up the thread, undid the nut and after taking it off it's chewed up either the nut or the axle or both I can't tell. But as it's only the end past the split pin hole I'm going to try and get hold of a die on the axle to clean it up and try to retap the nut because it looks like it would be ok to reuse. Pretty pissed off because it's all brand new parts and I've been very careful not to damage the stub axle on fitting. So does anyone know the thread size or even better a tap and die the correct size i could borrow?
27th Jul, 2014 at 02:01:16pm
5/8unf |
27th Jul, 2014 at 02:53:27pm
Thanks carl, put my tpi gauge on and it looks like 5/8" unf 18tpi is what I'm after. Now to try and borrow a tap and die before I have to part with cash for a one time use. On 26th Jan, 2012 Tom Fenton said:
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
27th Jul, 2014 at 06:02:48pm
was it from minispares by any chance? I had 1 from there and they must have drilled the split pin holes after threading it as the castle nut wouldn't go past until I got a mate to rethread it due to the drilling of the holes causing dodgy thread in the area Masturbation is not a crime its a hobby |
27th Jul, 2014 at 06:17:55pm
Yeah it was mate, both stub and castle nut were from spares, I'm not very happy about it especially as the stub axles are quite expensive for what they are.... On 26th Jan, 2012 Tom Fenton said:
27th Jul, 2014 at 06:42:57pm
27th Jul, 2014 at 06:46:38pm
I would if the stub axle wasn't in my radius arm! I'm gonna repair the stub axle as that's easily saveable, if the nut is fubard im gonna take it back and find an old genuine one, The finish on the castle nut is crap tbh and it makes me think its that at fault. On 26th Jan, 2012 Tom Fenton said:
