Home > Help Needed / General Tech Chat > Breathers? Not sure where/what to add.
seahuston
Member #: 10666
California, USA
Building up my 998 engine and realizing that I don't have any breathers on it left since I'm not use the rear tappet chest breather (due to turbo) and I'm not using the timing case breather because of a belt drive setup.
Do I need to add some breathers? Where/how should I add them?
You could put one on the transfer case, one on the rocker cover & if you are using mapped ignition use the dizzy hole as another.
seahuston
Member #: 10666
California, USA
Is there any reasoning for determining how many are needed? I don't want to go overboard with it
Too many is better than too few. The a series does like breathers
seahuston
Member #: 10666
California, USA
Thanks for the info. I think I'll have to add a breather to the flywheel case and the rocker cover. Could I also just use a catch can instead?
Chalkie
Member #: 9764
Northamptonshire.
I'm using Rear tappet, rocker cover & clutch cover
seahuston
Member #: 10666
California, USA
Is there clearance for the turbo and the tappet breather? I didn't think there would be.
Chalkie
Member #: 9764
Northamptonshire.
I wont be running a turbo but depends if your using the canstier type or the early pipe type if its the pipe type then it will clear
Bill
Member #: 10080
Holland, Eindhoven
with a supercharger is it better to put the carter air before the supercharger? This is a blow through set up.
Mike-998
Member #: 9774
Buckinghamshire
Definitely before, you dont want pressurised air going into your crankcase. Putting it before will help draw out all of the blow by and oil mist
