| Home > General Chat > having second thoughts. | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
6th Aug, 2014 at 04:29:14pm
Having seen on the imm how clean the engine bay of some turbo mini's are i am having doubts about my remote setup. .. although i did got to hear that it would be good for the weight distribution. My remote setup is made out of a small bore lcb( to keep the gasses flowing faster) the runners are not perfect equal but not far of. The exhaust is a 50 mm tube but with a sharp bent coming out of the turbo. . you can do anything if you set your mind to it...
6th Aug, 2014 at 04:41:10pm
Stick with it. I'd like to try this at some point. In the 13's at last!.. Just |
6th Aug, 2014 at 04:44:28pm
Keep going mate, just make it your own I have started posting on Instagram also my name on there is turbomk1golf
6th Aug, 2014 at 04:57:38pm
I'd rather have a usable bay than a tidy bay, you can always work on tidying everything up once you've worked everything out etc On 26th Jan, 2012 Tom Fenton said:
6th Aug, 2014 at 08:26:58pm
Guess i can always change it if it does not work out.
Edited by Rammie2000 on 6th Aug, 2014. you can do anything if you set your mind to it...
