| Home > General Chat > 21268 g7 l33 piston dish,oil pump and 286cam help! | |||||||
40 Posts Member #: 10537 Member |
6th Aug, 2014 at 05:24:02pm
Hello, im looking to convert my 1275 engine into a low boost turbo motor using a clutch mounted gt17 turbo. The engine is in really good condition and is fitted with a kent 286 cam, the pistons are marked 21268 g7 l33. Can anyone please tell me what size dish these pistons have and also what is the standard compression of this engine? Also would a turbo oil pump be needed or is the standard pump up to the job? As I may run it n/a for a while before fitting the turbo. Second to last question... will the kent 286 cam Be any good? Its not a daily drive but more of a weekend toy so not to worried about drivability as long as it makes good power when I need it, last question!... is a centre main strao going to be really needed for my set up? The reason I ask is because I have booked a week off work which I intend to work solid on the mini to try and swap the gearbox.fit the engine and make the manifold so dont want many hold ups.
6th Aug, 2014 at 05:32:36pm
I know for a fact that the 286 is going to be useless, best off selling it, buying something like an mg metro or 266 and pocketing the difference mate. Standard oil pump has been proven to be more than up to the job but the high flow item won't hurt if you feel like fitting it. On 26th Jan, 2012 Tom Fenton said:
6th Aug, 2014 at 05:42:39pm
Ok brilliant thanks for the fast reply! Do you know if the 276 is any good as I have one laying round or again is that useless? What are your views on a centre main strap? |
6th Aug, 2014 at 05:46:00pm
A 276 is better than a 286, but still not quite as good as something tamer, by all means you could try it and if you're happy with the results it gives continue to use it. There's no downside to fitting a cms, I'd fit one to any non standard engine just for piece of mind for the little cost involved On 26th Jan, 2012 Tom Fenton said:
6th Aug, 2014 at 07:23:42pm
Ok mate thanks so much for your help! Still after some info on these pistons, can anyone help?! :) also after having a think im not sure if the easiest route is a bulkhead box.. what are peoples thoughts on this? Thanks! |
6th Aug, 2014 at 09:49:51pm
you can get a gt17 down the back without a bulkhead box iirc Yes i moved to the darkside |
6th Aug, 2014 at 09:56:55pm
On a mildly tuned or low revving set up the centre strap is not needed. On 7th Oct, 2010 5haneJ said:
7th Aug, 2014 at 09:38:00am
Ok thanks guys :) im at the stave where I need to start ording parts so dont want to miss anything :) I was planning to makw my own manifold but dontwant the turbo to sit silly close to th bulkhead, rather than completly remove that section of the bulkhead and box section has anyone just made the box section smaller to allow clearence for the gt17? Also I will be running a distributor.. will a standard metro turbo dizzy work with my set up or am I better locking a standard dizzy up to stop too much advance? I would like megajolt but for the time being money is tight. Thanks!
10th Aug, 2014 at 10:04:56pm
Can anyone please tell me what compression ratio the 21268 pistons give? Also if there a decent piston for a low boost engine, would be ideal if I was able to run low boost without touching the compression ratio |
10th Aug, 2014 at 10:45:33pm
Having done the 286 cam 20 years ago with turbo....do not even bother. It's horrific.
11th Aug, 2014 at 08:52:13am
ok this is my tghoughts and take what you want but dont hold me responsible lol note beer..
11th Aug, 2014 at 01:46:35pm
Thanks turbo this.. that was what I was hoping to hear! |
11th Aug, 2014 at 07:44:11pm
Anyone advise the 276 or had experience with it? :) |
12th Aug, 2014 at 09:15:18am
I also may be able to get my hands on an n/a mg metro cam, are theses any good? How do I identifythe cam to make sure it is an mg metro? |
12th Aug, 2014 at 09:36:05am
right then first off search!
Edited by Turbo This.. on 12th Aug, 2014. |
