Home > Help Needed / General Tech Chat > Changing rear PCD
carts60
Member #: 9335
Bromley, SE London
So I currently have a set of 13" 4x100 wheels I am planning on running on the mini.
I know I can get some drive flanges to suit from Force Racing but is simply re-drilling the rear drums to allow the wheel bolts to come through OK?
I hope that makes sense!
Basically how do you fit rear flanges when the bolt pattern won't suit the standard holes in the drum!?
Edited by carts60 on 9th Aug, 2014.
You could re drill the new PCD in between the original bolt holes.
I seem to remember carl being able to add 4 holes of another PCD to a drive flange/ rear hub
carts60
Member #: 9335
Bromley, SE London
Thanks Matty,
Thats what I assumed. I just wanted to make sure the unused holes wouldn't cause any issues.
Yes Joe, he can produce alternate PCD drive flanges. Thats what I'll be using
I did mean an exxisting flange / hub
i think it was rover metro ones so you could put mini wheel'e on them, and see why it couldnt be ndont the pther way though
