| Home > Help Needed / General Tech Chat > bloody oil drain problems | |||||||
![]() 330 Posts Member #: 9628 Senior Member |
15th Aug, 2014 at 07:02:13pm
i need to change my oil drain design againnnnnnnn
On 29th Oct, 2012 Mike-998 said:
I just went to a local hydraulics shop with the turbo and asked if they had anything that would fit. I didn't end up using the part either, if its any use to you then you can have it?
![]() i want to try and order it off the internet because im going away for a week and would to have it when i come bcak, plus the turbo is still on the car does anyone know? |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
15th Aug, 2014 at 07:07:05pm
Its a normal connector for example a air compressor. If you know the tread and size you can order this from for example airpress. you can do anything if you set your mind to it...
15th Aug, 2014 at 07:08:35pm
On 15th Aug, 2014 Rammie2000 said:
Its a normal connector for example a air compressor. If you know the tread and size you can order this from for example airpress. HAHAHA thats what i was supposed to be asking for dohhhhhh i need to know the thread size :L |
15th Aug, 2014 at 07:11:27pm
I am going to guess m12 or m14 I have started posting on Instagram also my name on there is turbomk1golf
15th Aug, 2014 at 07:12:28pm
On 15th Aug, 2014 madmk1 said:
I am going to guess m12 or m14 can anyone comfirm? dont want to take a risk
15th Aug, 2014 at 07:12:56pm
how come your re inventing the oil drain?, we / us / them / "the people" have been fitting these turbos for years...its quite straight forward Yes i moved to the darkside |
15th Aug, 2014 at 07:16:22pm
Order both? Then you will know which it is there are only cheep.
15th Aug, 2014 at 07:16:58pm
The oil drain isn't threaded on most of the turbos I've had my hands on.
15th Aug, 2014 at 07:22:12pm
On 15th Aug, 2014 Brett said:
how come your re inventing the oil drain?, we / us / them / "the people" have been fitting these turbos for years...its quite straight forward the method i used isnt going to work, so i need to use some more similar to whats already been done. i bought a DSN turbo feed which was a mistake because i need something with 90* off the block then use a silicone 90* up onto the piece im trying to get the thread size for. |
15th Aug, 2014 at 07:23:34pm
On 15th Aug, 2014 apbellamy said:
The oil drain isn't threaded on most of the turbos I've had my hands on. If it's a GT17 or something similar, just get a heather outlet from the head and open the holes up a knat's cock. http://www.minispares.com/product/Classic/...es/12G2534.aspx its the same one thats on the pics i put up, just one big threaded hole :L |
15th Aug, 2014 at 07:26:20pm
I am going to guess m12 or m14 my heads not working what is that piece im looking for called?
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
15th Aug, 2014 at 07:29:26pm
Geoff On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
15th Aug, 2014 at 07:33:43pm
On 15th Aug, 2014 oli79 said:
Geoff This Guy? Yes i moved to the darkside |
15th Aug, 2014 at 07:35:51pm
15th Aug, 2014 at 07:36:35pm
15th Aug, 2014 at 07:39:42pm
Shouldn't Geoff be wearing his hat? On 11th Feb, 2015 robert said:
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
15th Aug, 2014 at 07:47:13pm
Only cheep?
Order both? Then you will know which it is there are only cheep. Then you can get you car going and get your MOT They don't die, they just get faster! |
15th Aug, 2014 at 07:58:36pm
On 15th Aug, 2014 coopdog said:
help a guy out haha To be honest chief, I have tried, in your last thread me, Andy and Stevie turbo all told you your drain wouldn't work and the response we got was On 31st Jul, 2014 coopdog said:
Okkkkkkk :( Then I took time to sift through my massive porn collection to dig out a picture of my old drain which is very similar to a lot on here to try and help you and all I got was On 31st Jul, 2014 coopdog said:
yeah ive got an idea on the way to do it now Not a cheers nore a thanks nore nob all, now I don't look for you to build a gold statue of me or have a tickertape parade in my honour but I would suggest a basic bit of manners may help you get more use full advice. were well into double figures in this thread and still no one's got the foggiest what turbo we are looking to name the thread for!!! I'm gonna waste a bit more breath here but If your trying to make an oil drain for a turbo on a mirage style mani returned into the fuel pump hole your gonna be out of luck, the clearances are so tight making one is really the only option imo On 18th Oct, 2013 apbellamy said:
15th Aug, 2014 at 08:04:48pm
UuuuuuuuuuUUUUUUUUuuuuuuuuuhhhh I have started posting on Instagram also my name on there is turbomk1golf
15th Aug, 2014 at 08:14:25pm
Oil drain you say?
15th Aug, 2014 at 08:45:38pm
yeah ive got an idea on the way to do it now Not a cheers nore a thanks nore nob all, now I don't look for you to build a gold statue of me or have a tickertape parade in my honour but I would suggest a basic bit of manners may help you get more use full advice. were well into double figures in this thread and still no one's got the foggiest what turbo we are looking to name the thread for!!! I'm gonna waste a bit more breath here but If your trying to make an oil drain for a turbo on a mirage style mani returned into the fuel pump hole your gonna be out of luck, the clearances are so tight making one is really the only option imo yeah thats what im trying to do, im going to have to make one from scratch which is a pain in the arse. i should of mentioned it is a water cooled T2 on a matty manifold and i was thankful i just forget to tell people sometime haha i do apologise for that. i did take all your advice on and i got rid of that copper pipe i had made and tried something else, but that didnt work either :( my idea now is using a fuel pump blank of piece welding a 90* on to it then having a 90* silicone hose up into the tubro. thanks guys :) Edited by coopdog on 15th Aug, 2014. |
15th Aug, 2014 at 09:14:38pm
I assume you mean something like the one on the right Mr PoopDog??
15th Aug, 2014 at 09:23:59pm
Notice the angle on the turbo outlet, a straight fitting may not work well. The bit on the block was a fucker to get flush, leaked a lot and ended up smothered in RTV to get it sealed. Yeah like the one on the right in the first picture, How did it work with the silicone pipe? This drain has caused me the most problems in the whole build haha Thanks again Edited by coopdog on 15th Aug, 2014. |
