Home > Help Needed / General Tech Chat > engine build lube
Chalkie
Member #: 9764
Northamptonshire.
Hey guys
Starting to build my engine back up what lube do you guys use? Engine will be sat for few months once built
Thanks Stephen
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
royal purple was my choice and it seems to hae worked fine
do rember that lube hides the "feel" a little bit so i recomend a mock up with light engine oil like 10 or 15 as this wil show any tightness or binding on the crank and rods cam bearings that said i dont recomend 10 or 15 for the intial lube i prefer build lube for that as it stays put untill full oil pressure has been acheved
only my opinion take what you will !
I used the torco lube from minispares
Torco for me
Torco for me
Graphogen and oil on the piston rings
Chalkie
Member #: 9764
Northamptonshire.
It's the rockers I'm building up first so torco be good for them? As it's with a heavy duty rocker shaft?
