Home > General Chat > Injector cleaning
steve w
Member #: 1917
AKA chargedzetec
Has anyone any experience of getting injectors cleaned?
If so, any recommendations for somewhere to get it done.
All 4 of mine won't fire. Wiring and fuel supply is fine, so I'm assuming they're old and gummed up. Unless there could be any other reasons for them not supplying any fuel??
Edited by steve w on 20th Aug, 2014.
I use these people:
http://www.injectorcleaning.co.uk/index.htm
You get a test certificate giving actual flow rates as well.
However, if all 4 are not firing, then it would suggest that something else is wrong.
steve w
Member #: 1917
AKA chargedzetec
That's what I was thinking, but all 4 have a live feed when the ecu powers up, and all 4 ground at intervals when then the engine is turned over???
Rig up a 12v feed an gnd
with a push switch.
evolotion
Member #: 83
Glasgow, Scotland
rattle them with the handle of a 3/8th ratchet whilst applying power. assuming they are just gummed. but all 4? im going with a wiring issue too.
Denis O'Brien.
Have you checked their resistance with a DVM, ie. to see the coils inside them are OK ?
Also, are they matched to their original ECU or is it an aftermarket ECU (high z and low z setups are different) ?
But, as already said, all 4 ???
steve w
Member #: 1917
AKA chargedzetec
I had that thought after I posted this.
Its an aftermarket ECU. Having checked, the old injectors were high impedance, new ones are low! 😖
ah...
I belive in a lot of cases you casn get away with adding a 10 ohm in line resistor... assuming you havent fried the ecu outputs.
