Page: |
Home > General Chat > Wheels: GB alloys, Minilifes or Rosepetals | |||||||
553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
27th Aug, 2014 at 07:28:57pm
Ok this is my car with 6x10 GB alloys now with a032s. Group two arches. Ive never been very good at fitting the chrome trim without getting it all kinked and twisted near where the arches meet the sill.
324 Posts Member #: 9441 Senior Member South Devon |
27th Aug, 2014 at 08:15:10pm
The steering might be slightly lighter but if you're running and same sized tyres I doubt you would recognise any great difference.
4890 Posts Member #: 1775 Post Whore Chester |
27th Aug, 2014 at 08:44:23pm
I'm a fan of gb's I run a supercharger and I don't care the TB is on the wrong side.
882 Posts Member #: 9774 Post Whore Buckinghamshire |
27th Aug, 2014 at 08:48:32pm
I can't comment on anything useful, but your car looks fantastic.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
971 Posts Member #: 3228 Post Whore North of the Netherlands |
27th Aug, 2014 at 09:01:10pm
On 27th Aug, 2014 Tupers said:
The steering might be slightly lighter but if you're running and same sized tyres I doubt you would recognise any great difference. When you come to fitting chrome trim put one coil in a bucket and pour a couple kettles worth of boiling water over it an leave it long enough for you to put you hand in. Once it's good a hot start at the back and knock it onto the seam with the palm of you hard. If it gets stiff pour more water from the bucket over the trim as you go. I've done 5 cars using this method this year. ^^ What he says; works a treat! Dazed and Confused.... |
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
27th Aug, 2014 at 09:01:56pm
U defo wont lose grip.. ive got 4.5 on my white one.. but after along time i wanted a mini on 10s and no arches n now i have one im not so sure :/ i prefer the look of yours.. unless the mini on 10s is stulidly low i dont like the look of it without arches On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
3249 Posts Member #: 1194 Post Whore Shropshire. |
27th Aug, 2014 at 10:55:28pm
GB's and group2's are perfect imo
Edited by MarkGTT on 27th Aug, 2014. |
1434 Posts Member #: 8466 Post Whore Mansfield |
28th Aug, 2014 at 07:16:59am
GB's all the way. Class C 3rd Place Avon 2011 14.18 @101mph |
28th Aug, 2014 at 10:26:04am
those are some tidy minis ! |
28th Aug, 2014 at 04:59:15pm
Cant remember where the arches came from, it was ages ago. I'm torn as i like all three wheels. I reckon there would be less torque steer with the narrower wheels with less offset. |
107 Posts Member #: 10760 Advanced Member Derby |
28th Aug, 2014 at 09:32:13pm
Love GB's. Got some on mine so a bit biased but always fancied a mk1 that you can put rosepetals on! |
2091 Posts Member #: 9894 Post Whore Dorking |
28th Aug, 2014 at 10:27:28pm
Looks cracking as it is!
690 Posts Member #: 9962 Post Whore |
29th Aug, 2014 at 07:03:55am
Based purely on how your car looks its already really nice as it is, colour, wheels and tyres
Edited by Aubrey_Boy on 29th Aug, 2014. |
29th Aug, 2014 at 06:18:17pm
On 29th Aug, 2014 Aubrey_Boy said:
Based purely on how your car looks its already really nice as it is, colour, wheels and tyres As far as how it feels and handles 165/70 R10 has a recommended fitted rim width of 4.5 - 5.5J from most tyre manufacturers So fitting a 4.75 x 10 Rose Petal from Minispares would probably make little difference to what you have in terms of how the tyre fits on the rim, the 4.75 being nearer to the recommended fitment nominal. So grip (pure traction) would be unchanged if anything a tiny bit better than being slightly pulled out on a 6J - but probably unnoticeable. The Rosepetal (C-21A1071) has a quoted offset of ET40, whilst I don't know the GB offset, looking at the 'dish' of the GB I'd say there's at least a 20mm difference possibly more. In terms of how the ET offset effects hub level lateral offset and torque steer the Rosepetal would be night and day better as 20mm plus is a BIG difference on ET and the effect it has. (Bear in mind that any current problem you have may not be solely due to the wheels / offset). IME everything else being equal, greater positive ET is always beneficial in terms of less 'steering corruption' - torque steer etc... As you say the track would be narrower so ultimately maybe a little less in terms of maximum cornering grip potential / ability. The steering weight should be a little less with less hub level offset. For me the Rosepetal is lighter, much better offset and the look of an archless 'App K' style car wins for me. The only downside is the Rosepetal is a little fussy on caliper clearance. Every mm spacer (if you need to add any) undoes the offset benefit 5mm spacer = effective ET35 offset. But I know plenty of Historic Race cars that run these exact wheels without spacers but needed mods to bleed nipple position Cheers Thanks. What you say makes perfect sense and was what i suspected. I don't yet have a torque steer problem, when i start my new engine we will see, but i think less offset will help keep it to a minimum along with the rest of the suspension set up being cock on. |
29th Aug, 2014 at 08:45:53pm
Thanks for the positive comments about how it looks |
21st Nov, 2014 at 09:32:33pm
Just bought 5 minispares rosepetals on sale. 15% off. Arches off already. Holes filled in. Will put some pics on my build thread soon Edited by dazibee on 21st Nov, 2014. |
1750 Posts Member #: 10190 Post Whore belgium |
21st Nov, 2014 at 10:02:26pm
i would have gone for steel wheels ( reverse one's with crome hub) you can do anything if you set your mind to it...
21st Nov, 2014 at 10:14:45pm
I like them too. So many choices |
6729 Posts Member #: 618 Post Whore Glasgow |
22nd Nov, 2014 at 06:57:02am
Rosepetals are a good choice
7264 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
22nd Nov, 2014 at 09:49:50am
Same angle photo with before and after would be great to see.
In the 13's at last!.. Just |
56 Posts Member #: 5200 Advanced Member Bath, Somerset |
22nd Nov, 2014 at 12:57:20pm
I'd be keen on the GBs if you decide to sell. |
22nd Nov, 2014 at 06:28:47pm
I will be looking to sell the gb's at some point. Got five, one unused, rest very good. Cant be arsed posting them, so thought they may suit someone who is in cornwall for the riveara run in may |
22nd Nov, 2014 at 06:55:41pm
Lovely mini. What brakes are you running? We want rose petals on one of our minis but hear d they may be a tighter fit than other 10" wheels depending on callipers /disks? |
22nd Nov, 2014 at 08:13:34pm
Lets see some photos of the rosepetals! |
22nd Nov, 2014 at 11:29:56pm
On 22nd Nov, 2014 PhilR said:
Lovely mini. What brakes are you running? We want rose petals on one of our minis but hear d they may be a tighter fit than other 10" wheels depending on callipers /disks? S disks and minispares grey four pot calipers |
Page: |
