Home > General Chat > Rear Alloy hubs - various options
Aubrey_Boy
Member #: 9962
At the moment I seem to just be adding weight and not saving any...
So in an attempt to go in the correct direction I have been looking at the various options for Alloy rear hubs, I just wondered what experiences or facts anyone has with any of them?
There seems to be:
KAD
SC / DSN
Minisport
Minisport seems to recieve widespread derision, I have never bought from them so have no experience myself. Just wondered what you thought?
I got the sc ones from DSN. I got discount due to being a TM member.
F415dda
Member #: 10595
Pembrokeshire,Wales.
I'm running the minisport ones and haven't had any problems so far..
Edited by F415dda on 28th Aug, 2014.
more speed 1293 turbo mini-180bhp 171tourque@15psi
best 80's mini at mini fair 2-2013 British mini fair 2014- runner up best 80
Top ten winner at players classic goodwood
Top 55 winner @imm2014
Runner up 80's @minifair 2-2014
Auto finesse sponsors choice award @ultimate stance 2014
mini fair best 80's winner 2015
I have the sc ones, and its a shame to hide them behind a drum.
jonny f
Member #: 9894
Dorking
SC again here.
No issues. Although I did have to grind a little off my grease caps to get them to go in.
Aubrey_Boy
Member #: 9962
Thank you for the feedback
Based on the images off the various websites I was already leaning towards the DSN / SC hubs, so I think I will go this way from what's been said.
In terms of pure weight saving I like the KAD rear disc conversion but the cost and the issues I have heard mentioned put me off so I plan to start with the usual ally hubs / superfins.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
then a tubular frame and arms to match
Aubrey_Boy
Member #: 9962
Turbo This..
Yes possibly, but the rear suspension is more of a headache than the front for me as it's all too easy to screw the camber stiffness up with trailing arms, so whatever I do I am going to do some ugly bar tests on the standard Mini stuff first as a benchmark.
Andy,
Thanks for mentioning the discount, every bit helps
I ordered a silver pair today so should be with me on Monday *Clapping*
All the stuff I have had from SC / DSN has been good quality in terms of machining and finish so more of the same hopefully
I'm on the SC ones too, and theyre fine, but as above the grease cap is pretty tight.
graemec
Member #: 1424
Carnforth, Lancs
I wonder if these would fit better? Probably easier to adjust:
http://www.minispares.com/image.axd?type=p...TB4098ALLOY.jpg
that will be very interesting.
skolawn
Member #: 69
Coventry
explain camber stiffness to me please
How much does the trailing arm twist in the direction of camber when you apply a load to it.
Aubrey_Boy
Member #: 9962
Skolawn,
If you attach a scaffold pole (Ugly bar) rigidly to the rear hub, hold the scaffold tube at 12 o'oclock then push / pull as though you are trying to increase or reduce the camber.
If you pushed with a force of 10 Newtons and your scaffold was 1 metre long and the hub moved through an angle of 1 degree you have a camber stiffness of 10 Nm/deg. The bigger the number the higher the camber stiffness.
Tom,
I haven't tested the Mini yet as I need to get the car in a position where there's enough room to do the tests.
