| Home > Help Needed / General Tech Chat > Flitch panel repair | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
30th Aug, 2014 at 12:30:33pm
Hi guys, does anyone know if any of the mini magazines did a complete flitch panel repair 'how to' in their tech section, if so which issue?
30th Aug, 2014 at 12:39:43pm
I generally mount it up with door and a panel to make sure I'm happy with the position; don't rely on the hinge holes though; I've never found a repair where they were in the correct position |
30th Aug, 2014 at 12:44:14pm
Hi Rob, yeah that was my issue.. Pretty much had it clamped temporarily in place with the holes aligned and the top (where it meets the post) is sticking out. That's why I wanted a look... |
30th Aug, 2014 at 02:11:33pm
Is the door post still in tact? |
31st Aug, 2014 at 12:12:52am
It is yeah... Removed some of the inner post but outer is intact.. |
![]() 324 Posts Member #: 9441 Senior Member South Devon |
31st Aug, 2014 at 01:11:15am
On 30th Aug, 2014 evad1980 said:
Hi Rob, yeah that was my issue.. Pretty much had it clamped temporarily in place with the holes aligned and the top (where it meets the post) is sticking out. That's why I wanted a look... Do you mean there's a gap between the thick piece of steel with the hinge holes in and area of the flitch that bends over it at 90 degrees for the A-panel to pean over? If so then there normally id a 1-2MM gap. A couple picture would help. |
31st Aug, 2014 at 11:31:55pm
No it's sticking out at where it meets the windscreen pillar. Looks like it needs a bit of persuasion with a relevant tool! No pics at the mo... |
1st Sep, 2014 at 08:40:41am
photos would help |
1st Sep, 2014 at 10:55:25am
ok heres a few pics...
