| Home > Help Needed / General Tech Chat > Wobbly Flywheel + Clutch! | |||||||
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
3rd Sep, 2014 at 02:00:50pm
Been in contact with MED today because the RTS assembly I sent them (built by me) has a 50thou run out on the rear face of the flywheel. I asked them to take the flywheel off and check the pressure plate and that has a 32thou run out.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
3rd Sep, 2014 at 02:02:44pm
Burr or swarf between the verto hub and stamped steel plate? On 17th Nov, 2014 Tom Fenton said:
4th Sep, 2014 at 09:57:39am
not sure maby some crud in the taper?
Edited by Turbo This.. on 4th Sep, 2014. |
109 Posts Member #: 10368 Advanced Member Australia |
4th Sep, 2014 at 10:26:18am
possibly previous owner lapped the flywheel on but forgot to remove the paste? |
4th Sep, 2014 at 11:02:07am
Could it be the electroplating on the hub has built up unevenly?
976 Posts Member #: 3228 Post Whore North of the Netherlands |
4th Sep, 2014 at 12:07:01pm
On 4th Sep, 2014 Mike-998 said:
I'm fairly sure it was assembled clean but I'll ask them to take it apart and look for Swartz etc.
Dazed and Confused.... |
5th Sep, 2014 at 07:31:18am
Did you remove the centre boss from the main steel plate whilst doing the work ?
5th Sep, 2014 at 08:26:06am
On 5th Sep, 2014 Rod S said:
Did you remove the centre boss from the main steel plate whilst doing the work ? (I did because it made drillng the rivets out of the plate easier) If so, all the original factory bolts I've seen have been centre punched on their end to act as additonal locking so could have raised a burr on the steel plate, mating side, as they came back through it. Also, did you notice the centre boss "should" only go back in one position - the six holes are not equally spaced but the difference in spacing is very small. If the clearance in the bolt holes was large (or someone in the past had enlarged them because they didn't realise it only goes one way) it "might" be possible to assemble it wrong. (on mine the bolt hole clearances were very tight so it would not have been possible). Nice info Rod, very useful! (much more useful than my act.. srry, could not resist!) Dazed and Confused.... |
5th Sep, 2014 at 08:54:20am
Thanks Rod, I did remove the hub from the plate whilst doing the work, I didn't notice any centre punch marks on the bolts but then I don't think I really looked. That could be a possibility.
5th Sep, 2014 at 10:06:41am
On 5th Sep, 2014 Mike-998 said: Or it may have already had a replacement ftted, the kits I've seen just have the pre-coated thread locking compound on the bolts and no instructons to punch them, in which case the burrs may have been raised in the past.
Thanks Rod, I did remove the hub from the plate whilst doing the work, I didn't notice any centre punch marks on the bolts but then I don't think I really looked. That could be a possibility. On 5th Sep, 2014 Mike-998 said: Good, that eliminates that possibility.
I did find that the holes only lined up one way, and all the bolts spun in freely iirc. Sorry, no further suggestions. Presumably MED have a dummy crank tail (or spare crank) so can clock the centre boss by itself to check it runs true? Schrödinger's cat - so which one am I ??? |
5th Sep, 2014 at 11:37:34am
Try a different boss ?
5th Sep, 2014 at 11:46:46am
Thanks for all the help, I've just spoken to MED and they're going to try all the suggestions. I'll update this with anything they find. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
5th Sep, 2014 at 12:53:12pm
Sounds expensive I run a supercharger and I don't care the TB is on the wrong side.
5th Sep, 2014 at 01:03:39pm
On 5th Sep, 2014 gr4h4m said:
Sounds expensive I sure hope not! It's looking like it can only be the hub or the pressed steel plate. I have a spare steel plate from the other clutch I took apart which would just need drilling and tapping and I shouldn't have thought a good hub would be too hard to find? Fingers crossed anyway http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
5th Sep, 2014 at 03:47:20pm
I mean med doing all this trial and error stuff, won't they be putting the price up I run a supercharger and I don't care the TB is on the wrong side.
5th Sep, 2014 at 04:39:19pm
Ah I see, at the moment they have been very helpful and reasonable, but if they can't find anything obvious I'll have to pick it all up. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
