| Home > Help Needed / General Tech Chat > Sc drop gears needed? | |||||||
116 Posts Member #: 10945 Advanced Member scarborough/ northyorkshire |
3rd Sep, 2014 at 07:12:30pm
What sort of power would you say I need sc drop gears, I'm not wanting to put them in if not needed because of the noise mainly, cheers phil |
3rd Sep, 2014 at 07:21:20pm
an interesting question,
3rd Sep, 2014 at 07:29:38pm
in short, as joe says, but you need to run a SC gearset, with helical drops, better to put your money in the gearset and have better ratios than paying for noisey SC drop gears
3rd Sep, 2014 at 07:47:43pm
My old age is showing as I also would run helical drops on everything but a race car these days, however I would make a point of ensuring that your helical drops are in top condition (particularly the primary gear bushes) and ensure that primary and idler end float are correctly set. I would also replace the idler bearings and the 1st motion nose bearing + race as a matter of precaution If something is worth doing, it's worth doing half of. |
3rd Sep, 2014 at 08:13:21pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=381228 Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
4th Sep, 2014 at 05:55:57am
Cheers lads, il be putting fresh bearings in where I can, is it the torque or high rpm that kills then or just abit of both, |
4th Sep, 2014 at 07:41:17am
the torque, or misalignment form worn bearings IMO
4th Sep, 2014 at 10:16:11am
i can say if your getting a straight gear set imo its worth the extra for a quality set like med super finish the kit i got is ruff and lose to say the least there seems to be a lot of back lash well i think its a fair bit altho not as much as my old helical set it had clasped bearings... |
301 Posts Member #: 10610 Senior Member Wiltshire |
4th Sep, 2014 at 10:54:53am
I've got sc drop gears, I find that the intake sound(cone filter) is just as load as the gears when cruising. |
