| Home > Help Needed / General Tech Chat > Thermostat housing | |||||||
![]() 66 Posts Member #: 10948 Advanced Member swansea. south wales |
6th Sep, 2014 at 08:26:16am
Are the thermostat housings the same on std mini 1275's as the ones fitted to metro turbo heads? Your here for a good time! Not a long time!
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
6th Sep, 2014 at 10:49:03pm
There is no same thermostat housing, there are many different ones with different angles, metro ones normally have the spacer underneath with heater take off like some late 1275s On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
6th Sep, 2014 at 11:37:37pm
there the same bolt pattern and use the same gaskets, they are slightley angled diffrent, metro to mini but most if no all interchange
7th Sep, 2014 at 07:01:45am
Cool thank you. I knew they were pretty similar bud didn't want to commit to buying the wrong one! Obv with cooling being a big prob with turbo'd minis i was going to run with out a thermostat or would u guys recommend a low opening temp one? Edited by franky4x4 on 7th Sep, 2014. Your here for a good time! Not a long time!
7th Sep, 2014 at 07:57:02am
If running without a stat you'd need a blanking sleeve to create a restriction to the flow in order for the cooling system to work as it should On 26th Jan, 2012 Tom Fenton said:
7th Sep, 2014 at 08:01:31am
Ahh ok thanks low temp stat it is then!!!
