| Home > Technical Chat > Turbo cranks | |||||||
10th Aug, 2005 at 06:02:17pm
i have a turbo crank that is stamped CAM6232 yet i belived Turbos were fitted with CAM6581 this is an original engine that i pulled out of a metro turbo a few years back and the engine number matched the log book? Crystal Sound Audio said:
10th Aug, 2005 at 06:23:34pm
it was either early or late ones that had the 6518...but they also did them with the 6232's which is a normal A+ crank...i've had one of each in the 2 turbo engines ive had. On 20th Oct, 2015 Tom Fenton said:
10th Aug, 2005 at 10:08:27pm
mid 85ish seemed to be when the switch to the 6581 occured from what I've gathered from ages of engines folks have stripped down.
10th Aug, 2005 at 11:33:20pm
no i remember it was really quite tidy though
11th Aug, 2005 at 04:38:20pm
butcher |
11th Aug, 2005 at 05:17:34pm
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
11th Aug, 2005 at 05:59:07pm
Candlestick maker |
11th Aug, 2005 at 10:18:13pm
I thought one sort had crossdrilled mains as standard,but never seen one
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
11th Aug, 2005 at 10:23:31pm
was there any ones that were slightly better then others "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
11th Aug, 2005 at 11:36:34pm
No A+ series crankshaft was fitted with cross drilled mains. No A series either for that matter. On 13th Jul, 2012 Ben H said:
11th Aug, 2005 at 11:53:52pm
whats this mean then
Edited by Dangerous on 11th Aug, 2005.
12th Aug, 2005 at 10:13:17am
Why didn't you read the last link to Minispares then??
12th Aug, 2005 at 01:30:41pm
Wonder where Ben got that 'bogus' information?
12th Aug, 2005 at 02:23:50pm
http://www.minimania.com/web/SCatagory/ENG...46/ArticleV.cfm On 28th Aug, 2011 Kean said:
14th Aug, 2005 at 07:50:47pm
But they aren't..... I don't understand this at all. On 13th Jul, 2012 Ben H said:
14th Aug, 2005 at 09:44:20pm
On 14/08/2005 19:50:47 Vegard said:
But they aren't..... I don't understand this at all. Nor me
Unless its very early ones,as there is a rumour that the turbo had a en40b crank too
14th Aug, 2005 at 11:00:54pm
from what ive seen from turbo cranks is that they were nitro carbonised weres the standard and NA MG was a standard casting and non traeted and used different shells. always looking for them bigger bunches of bannanas |
15th Aug, 2005 at 01:36:32pm
As I've said on many different occasions, you simply don't take out a new forging for a different 'final process' ie heat-treat...
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
19th Aug, 2005 at 09:38:47am
easiest way to identify a turbo /non turbo 6232 is to look at the machined ends ie timing chian spigot , clean with thinners and the turbo one will be a grey finnish indicating heat treatment rather than reflective 'steel'
19th Aug, 2005 at 11:17:30am
This info is up for debate, having said that.....
