Home > General Chat > this summers rolling road result
welshdan
Member #: 1111
s wales
Hi gents, this is a few months late but haven't had chance to upload this.
Basically I fitted a larger intercooler to my motor, as well as upping the boost a bit.
prev power was 160 bhp with the smaller (2wd cossie intercooler), at 13 psi
this run was done at 16psi, 4wd cossie intercooler. now produces much more torque. the car absolutely flew on the way home. but only 174 bhp
The old run was done at sub 10 degrees ambient. this run was done at around 20 degrees.
To be honest I was hoping for 180 plus given the previous runs. However it drive very well.
enough waffle, here are the figures
have taken it out since and have had fuelling issues. this seems to be a lon standing intermittent problem. the t piece trick did not resolve this so will be rebuilding the carb over winter in a hope that this will correct things.
Dan
Edited by welshdan on 15th Sep, 2014.
welshdan
Member #: 1111
s wales
pics will not rotate unfortunately gents
mossy2a
Member #: 9751
Derbyshire
impressive figures
Nice numbers
nice
welshdan
Member #: 1111
s wales
cheers men. need to sort the fuelling issue once and for all. run a low compression ratio so could up the boost to around 20 psi plus but its an absolute hand full on the road as it is! will have to see how things go
safe mass Boost = Fun!
