| Home > General Chat > Megajolt spark cut using afr oupt to prevent damage to engine? | |||||||
15th Sep, 2014 at 05:43:09pm
Just a thought that popped into my head whilst walking home from work, is there a possibility that you can use the output from the wideband controller 0-5v to trigger something on the megajolt unit that will cut the spark/retard timing etc when the engine starts running lean? Just thinking it could be a useful safety feature I could add to Shauna's mini whilst I'm in the wiring phase of things, if that's even possible? The megajolt unit is a v3.
15th Sep, 2014 at 06:46:22pm
possible but youll need to code the ecu to do it conditionally, i.e. lean on cruise/over-run is desirable but you dont want it spark cutting then, best do it with a pressure threshold. also engines will occationally missfire or do an incomplete burn this could trigger your safety thing needlessly.
15th Sep, 2014 at 06:48:30pm
K.I.S.S.
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
15th Sep, 2014 at 06:50:02pm
On 15th Sep, 2014 Tom Fenton said:
K.I.S.S. They don't die, they just get faster! |
15th Sep, 2014 at 07:05:09pm
Yeah, it would be nice if something like this could possibly be a built in feature using the map and the afr input, then as you say it would only do it conditionally. Just a passing thought i had on the walk home haha. On 26th Jan, 2012 Tom Fenton said:
15th Sep, 2014 at 09:05:38pm
doesnt mjlj have the facility to pull timing based on a temperature input?
Yes i moved to the darkside |
15th Sep, 2014 at 09:45:52pm
just had another look over this, now i have my mapping laptop out it looks like this could be fairly easy to achieve
Edited by Brett on 15th Sep, 2014. Yes i moved to the darkside |
