| Home > Help Needed / General Tech Chat > manifold problem | |||||||
15 Posts Member #: 10908 Member norfolk |
18th Sep, 2014 at 07:29:18pm
Hi can anyone help, building up engine and on final stages now but have found that the exhaust manifold middle branch will not seat against head, outside two nice and tight though. Any advice please. |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
18th Sep, 2014 at 07:46:47pm
needs machining by the sounds of it Done now needs redoing lol |
18th Sep, 2014 at 07:56:29pm
Yeah that's what I was thinking of doing, just Damn annoying finding it when nearly ready to fire up |
19th Sep, 2014 at 07:19:54am
try putting a straight edge across the flanges should be flush across all three if it is you have problems with your head. shouldn't cost too much to be machined Done now needs redoing lol |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
19th Sep, 2014 at 08:43:34am
be careful if you have it machined that the rear of the flanges are flush with the inlet manifold, otherwise you will have to make up some stepped washers.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
20th Sep, 2014 at 08:39:56am
It's a turbo manifold, will take it off again and check It, it's not head as it all just been done.
needing a inlet manifold which is holding me up too, tried to fit a normal cooled one with some adjustments but still no fitty
