| Home > Help Needed / General Tech Chat > front bearings.. not what id call 'spinning freely' | |||||||
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
20th Sep, 2014 at 11:52:09am
Hi guys.. not the turbomini but the little 998 daily hack... noticed a bit of play in front drivers wheel and as i took split pin out to adjust the nut was loose! Nipped it up to 150 (with washer trick too) and the wheel wouldnt spin freely like id like... nocked it back a little to line up the hole and it spins a bit better but not 'freely' ive left it at that for now and the mini rolls easily enough? The bearings were all new about a year ago and roughly a 1000 miles, mot was only a month n say 100 miles ago? Was fine then? So is it dangerous to have slight resistance? Or will this go in use? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
20th Sep, 2014 at 12:21:44pm
I would probably say it running loose has damaged the wheel bearing, me personally I'd get it changed asap. On 26th Jan, 2012 Tom Fenton said:
20th Sep, 2014 at 12:45:57pm
could be somthing else going on, nipping the nut up may have pulled the disc against the pad so it holds up a bit, which should sort itself adter a drive round the block.
20th Sep, 2014 at 12:52:24pm
I understand your view carlzilla, hopefully something silly like joe c says... could well be as it is more free at certain parts of the spin.. this is all a slight grip to the wheel.. i dont want people thinking im driving dangerous.. a quick spin round the block n it felt ok n was no nasty noises, will check again after a couple more miles On 24th Oct, 2015 jonny f said:
20th Sep, 2014 at 01:03:10pm
It's gotta be worth whipping the caliper off to check it's not pad rub too as Joe says, if it's not making any noise and nothing is loose I'd probably say see how it goes but get a spare one on the shelf just incase On 26th Jan, 2012 Tom Fenton said:
20th Sep, 2014 at 06:07:17pm
is it the roller taper bearing or the ball bearing type bearing? Yes i moved to the darkside |
20th Sep, 2014 at 06:17:39pm
