| Home > Help Needed / General Tech Chat > 1100 crank in 1275 engine | |||||||
166 Posts Member #: 8952 Advanced Member Athens Greece |
21st Sep, 2014 at 09:37:26pm
Hi to all,
21st Sep, 2014 at 09:40:51pm
no, the small bore 1100 crank main bearing journals are smaller. There is the South African 1100 big bore crank though which will work On 26th Oct, 2004 TurboDave16v said:
22nd Sep, 2014 at 05:21:20am
Thanks Sprocket |
22nd Sep, 2014 at 09:07:59pm
Aren't the SA lumps large bore, short stroke 1100?
In the 13's at last!.. Just |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
23rd Sep, 2014 at 10:12:26am
but then you don't get 1275 annymore? so what is the use of it? making a high rev engine? you can do anything if you set your mind to it...
23rd Sep, 2014 at 11:18:20am
Exactly In the 13's at last!.. Just |
23rd Sep, 2014 at 07:45:34pm
On 23rd Sep, 2014 theoneeyedlizard said:
Exactly And if one were to fit a 16v head and turbo it, no doubt an impressive piece indeed. On 7th Oct, 2010 5haneJ said:
23rd Sep, 2014 at 09:33:37pm
Exactly And if one were to fit a 16v head and turbo it, no doubt an impressive piece indeed. Jim?........ On 26th Oct, 2004 TurboDave16v said:
