| Home > Help Needed / General Tech Chat > BMW K Head : To Dry Deck or not to Dry Deck? | |||||||
211 Posts Member #: 10890 Senior Member Twin Cam Turbo Build In Progress Rothwell, Northants |
25th Sep, 2014 at 10:10:53pm
So should I dry deck a K head Turbo or not?
25th Sep, 2014 at 11:00:25pm
Yes, its worth it just to save money on the gasket imo. |
25th Sep, 2014 at 11:26:34pm
? You still use the gasket when dry decking ? |
26th Sep, 2014 at 09:39:15am
On 25th Sep, 2014 wayne miller said:
? You still use the gasket when dry decking ? Yes lol drydecking stops oil and coolant from passing from the block to the head via the head gasket, you still need.a head gasket The advanyages are you can use a normal mini head gasket instead of a special one, Also if you blow the gasket you dont loose coolant or oil Edited by Brett on 26th Sep, 2014. Yes i moved to the darkside |
26th Sep, 2014 at 10:14:58am
OK So I guess that by dry decking I remove the chance of water or oil cross contaminating and getting into my cylinders. I also read that it helps improve the cooling of cylinder#4 clutchside. Yeah I guess theres the added bonus of being able to use standard gaskets (with the new stud config punched in).
